iDRAC6 redfish SSL: DH_KEY_TOO_SMALL
CMK version: 2.3.0p22 CRE
OS version: Ubuntu 24.04.2 LTS
Error message: /redfish/v1 (Caused by SSLError(SSLError(1, ‘[SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:1000)’
Hello
Maybe the wrong forum but I encountered this with CheckMK.
I’m just moving over from SNMP to redfish. I have an old server running using iDRAC6. Server with iDRAC7 or higher have no problem. If I query the server with the redfish plugin, I receive a common error. With the redfish command I receive the above error.
> /omd/sites/cmksite/local/lib/python3/cmk_addons/plugins/redfish/libexec/agent_redfish -u xx-HOST02 --password-id uuiddxxxxxxxxxxxxx:/omd/sites/cmksite/var/check_mk/passwords_merged -P https --timeout 20 --retries 5 --verbose <ip>
> INFO 2025-09-20 17:58:55 root: using Python interpreter v3.12.3.final.0 at /omd/sites/cmksite/bin/python3
> INFO 2025-09-20 17:58:55 redfish.rest.v1: Attempt 1 of /redfish/v1
> INFO 2025-09-20 17:58:57 redfish.rest.v1: Retrying /redfish/v1 [HTTPSConnectionPool(host='<ip>', port=443): Max retries exceeded with url: /redfish/v1 (Caused by SSLError(SSLError(1, '[SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:1000)')))]
Search in the internet → found the keysize too small. I set the keysize to 2048
/admin1-> racadm getconfig -g cfgRacSecurity -o cfgRacSecCsrKeySize
2048
I recreated a new csr. The csr was now longer that the csr with 1024 (just to make sure the keysize is honored). Uploaded the certificate but the error is still the same.
I appreciate any help/hint.
Regards
I’m sorry for not answering your question & butting in anyway, but the older iDRACs have so little CPU power & have such an outdated software stack that I recommend staying with SNMP which uses much less CPU that the web interface, which is what Redfish uses (HTTPS API). By “older” I basically any iDRAC hardware which released with a version before 9. Even with an iDRAC that came with 9 pre-installed a full run of the Redfish plugin can take ten seconds of constant queries.
With older models I even had issues with timeouts when using SNMPv2 with bulk queries.
iDRAC 7, the successor, came out in 2012; so yeah, the iDRAC hardware your version 6 runs on must be in the ballpark of 15 years. Kudos if the server still works fine, of course.
If it is realy IDRAC 6 then i would say the same as @mbunkus - only use SNMP, beside this, i think IDRAC 6 doesn’t support Redfish.
For the older IDRAC 8 i would recommend only to fetch the overall system state with Redfish.
The good point is that you see if a subordinate component has a problem and you need to take a look. This is the same as i do it for older iLO4 if fetching the whole data takes to long as @mbunkus mentioned.
Thanks for the answer.
Yes, 1 server really runs version 6. This I didn’t want to read :sunglasses: :wink:
I wanted to move over to redfish because I have problems with SNMP. A SNMP query runs more than 10 seconds on serveral servers and sometimes it runs into a timeout.
OK, I will switch back to SNMP for this server. Thanks
regards
Yeah that’s what I was experiencing, too. That’s why I wrote what I wrote. You can alleviate some of the pain with SNMP rules (longer timeout per check, more re-checks, higher check interval in general), but even then the hardware fails sometimes. I feel your pain :joy:
According to Wikipedia you’re correct: 7 was the first release with Redfish support.
Hello
I reverted iDRAC6 back to SNMP. Continued on other hosts running iDRAC7. On some hosts I also received “(Caused by SSLError(SSLError(1, '[SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:1000)”.
I checked/set the keysize to 2048. I worked with the local racadm on the iDRAC host.
/admin1-> racadm get iDRAC.Security
[Key=iDRAC.Embedded.1#Security.1]
CsrCommonName=DhwHost01
CsrCountryCode=AT
CsrEmailAddr=support@xxxxx.at
CsrKeySize=2048
CsrLocalityName=Vienna
CsrOrganizationName=xxxxx
CsrOrganizationUnit=IT
CsrStateName=AT
CsrSubjectAltName=
FIPSMode=Disabled
Created and downloaded a csr. Signed it with my Checkmk CA and uploaded it back to the iDRAC host. After the reset I see the certificate in the brower but I still get the same DH_KEY_TOO_SMALL error.
Can you please explain/assist me to solve this issue.
Thanks and regards
CSR key size has nothing to do with the DH Key. The Diffie-Hellman exchange comes before your certificate enters the game.
This problem can only be solved with newer firmware for the device. But i think you will not get any up to date firmware for iDRAC 6 anymore. iDRAC 6 released 2008 - discontinued 2012 - latest firmware from 2019. With iDRAC 7 it is not much better.
