As docker volumes are constantly changing and in our case don’t need to be monitored I want to exclude them from check_mk discovery, so basically, everyhting under /vol/raid/docker/overlay2.
Probably the literal string as it is discovered otherwise: Filesystem /vol/raid/docker/overlay2, or when applicable you can do regex too like .*/docker/.
Edit:
Oh, and good to know is that it looks for all services that starts with the string or regex you put in.
If you don’t want other strings to be matched that starts the same, close string with $
Silly example, if I want to ignore / but not /tmp, string would be Filesystem /$
