My question is how to transfer some of this metrics as service to check_mk server.
At this moment I have only 1 service per IIS “service”, it is Web Service SERVICENAME.
As I can see at output from cmk -d HOSTNAME there are lots of info about IIS server but how to make it avaible at GUI. It is possible at all?
I unfortunately not a administrator of this check_mk instance and my ability to upgrade it to newer version is limited. But @mike1098 what you mean in case of extend the check wmi_webservice? And could you point mi some direction? I’m complete newbie in chek_mk env but i have some experience with nagios-like stuff so maybe I can handle it Please just point direction
Its not complete but could give you an idea how it works.
Basically you copy the check wmi_webservices from ~/share/checkm/checks to ~/local/share/check_mk/checks and then start altering the code. Anyway you should not do this in a productive environmnet.
For 2.0 its better documented and there is a standardized check API.
To be honest i start to like this way of extend monitoring, but how I can get it work? It stops threw errors at GUI but no new services appear.
At link you provide I see something about man_pages.py but I can’t found it so far. Also I not believe that this is so important and stops adding services to my hosts.
