ImportError: libssl.so.1.1
I just upgraded from 2.2. 0 to 2.3. 0p19 on a Debian 12 server
I enabled automatic agent upgrade, but on some older CentOS 6 systems, after upgrading, I get this error:
# cmk-update-agent -v -r
Updated the certificate store "/var/lib/check_mk_agent/cas/all_certs.pem" with 5 certificate(s)
|  Checkmk Agent Updater v2.3.0-2024.10.08 - Update                |
Getting target agent configuration for host 'xxxx' from deployment server
Target state (from deployment server):
  Agent available:     True
  Signatures:          1
  Target hash:         0bc1110e2edacc9e
Agent 0bc1110e2edacc9e already installed.
Forcing reinstallation.
Downloaded agent has size 15962396 bytes.
Error loading certificate #1
  File "cmk_update_agent.py", line 141, in check_signatures
  File "site-packages/cryptography/hazmat/backends/__init__.py", line 15, in default_backend
  File "/opt/Python-3.7.6/lib/python3.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 623, in exec_module
  File "site-packages/cryptography/hazmat/backends/openssl/__init__.py", line 7, in <module>
  File "site-packages/cryptography/hazmat/backends/openssl/backend.py", line 75, in <module>
  File "site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 16, in <module>
ImportError: libssl.so.1.1: cannot open shared object file: No such file or directory
No valid signature found.
See syslog or Logfile at /var/lib/check_mk_agent/cmk-update-agent.log for details.
how can i solve it?
Thanks,
Andrea
Hi @Andrea_Gabellini,
Centos 6 is End of Life since November 30, 2020.
In the Migration Notes for the 2.3 Update, there is the following note, that might be the actual issue you are facing:
TLDR: Centos 6 probably does not support OpenSSL 3, thus the feature won’t work on this system.
Can you check which OpenSSL version is available on your system?
In general, I would only use the auto update feature on supported operating systems that are not legacy or end of life. :slight_smile:
Best Regards
Norm
Thanks for the reply.
I know I have an EOL system but I can’t turn it off at the moment :frowning:
I tried to compile the latest version of openssl 1.1 and install it in parallel. Now it seems to work fine.
