Improve Logging
Please improve the logging functionality. The logs are very limited for both alert handlers and notifications in the GUI. When I need to view the actual logs, I have to manually go into the relevant server and use the CLI to move and change permissions on the log files and then download them using SFTP. It would be much more convenient to be able to download or at least view these logs directly in the GUI.
logs
Notifications only shows failures, no successes. It would be helpful to be able to see all logs and also to be able to download the raw log files.
