**CMK version:**2.00
Issue:-In a switch one of the power supply is showing CRIT but as i check physically all the power supply is OK. What could be the possible issue here?
Error message: Status not functioning source AC
You could check manually if the OID in question is really used for powersupply. OIDs could be different from one vendor to another.
Just use ‘cmk -vv HOSTNAME’ on cmk-server.
Also a little bit more information would be good. Like - what check is affected. The output the check shows and so on.
