in which bakery rule and parameter is it possible to increase the logwatch file size limits, so that the file size will exceeding the size of 489K?
Our problem is that the monitoring is doing its job only some hours but if the file under:
/omd/sites//var/check_mk/logwatch//
is larger than 489K no more lines are added by logwatch.
But why and where are the limits defined?
Logwatch is not planed to be used as log collector with history of all logs. You should define logwatch rules so that only monitoring relevant log entries are saved. Everything else should be discarded. And it is important that someone is overseeing the incoming messages, fix it or at least forward it to a person responsible and clear the log file on the CheckMK server. The 500k limit is by the way on the CheckMK server side, not on the agent.
Hello Udo
Thanks but what is the rule name with the parameter to find in Checkmk in which section?
Do you’ve a screenshot for us please?
Please let us know.
Thanks
Hello Udo
Sorry but we searching the parameter to increase the files size of logwatch.
We whats to get the log informations not discard them by rules.
The file size is just to increase.
But how?
