I’m using " Check_MK 1.5.0p12" and try to install the OpenHardwareMonitor plugin.
I did already download the files from the agent section and tried to place it in the plugin folder.
In other forum topics I saw, that the files should be placed at “C:\ProgramData\Checkmk\Agent\bin”, but I do not have an CheckMK folder at ProgramData.
All of this I tried and nothing works, do you got any other idea?
Currently the original OHM is running in the background of the server and it’s working fine.
