i am getting this errors when tryng to install check-mk-raw-2.2.0p12_0.jammy_amd64
This is a network-connectivity issue. The error-message indicates that the server you are trying to install checkmk on can not connect to the Ubuntu Repository to download the needed dependencies for checkmk. You have to make sure your server can access the Ubuntu package-repository before you can install checkmk.
You have to reach out to the security people again:
And when this is resolved, run
apt-get -f install
what port does the installation use
The sitename cannot contain spaces (blanks).
