I’m working on a integration between Checkmk and Apache Guacamole. Here is how it works:
1 - The integration connects to Apache Guacamole and retrieves all the connection ids and details of all connections.
2 - The integration connects to Checkmk and creates all the connections that are not available and provides apache guacamole protocol as a label
3 - Checkmk based on service labels monitor the availability of each connection using ICMP and the respective TCP port based on the assigned label.
As you can see the integration is working as I expect but I want to check if it somehow could be converted into an MKP as it relies on external stuff. I would like to define Apache Guacamole credentials using Checkmk GUI, create the cron job manually and let its execution be monitored by Checkmk.
Future:
- Makes the integration work in any way Checkmk>Apache Guacamole or Apache Guacamole>Checkmk
- Allow the exclusion of connections that are not working for some time
- Allow the RDP,SSH,VNC,TELNET to be started directly from Checkmk interface
Observation: Apache Guacamole is being monitored by Checkmk and both solutions are running in the same server which for my use case is perfect.
