Invalid configuration variable 'vss_shadow_storage_inventory' --> Found 1 invalid variables
**CMK version: **
2.1.0p37
OS version:
RedHat 8.5
Invalid configuration variable ‘vss_shadow_storage_inventory’ → Found 1 invalid variables
Hello guys. I am writing a plugin and it fails after adding a discovery rule. Simulation works fine and services are being generated. But after adding the discovery rule, the whole cmk crashes.
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright (C) Forvia <https://www.forvia.com/>
# Developer : Jan KUCERA <jan.kucera@external.forvia.com>
from pathlib import Path
from typing import Any
from .bakery_api.v1 import FileGenerator, OS, Plugin, register
def get_vss_shadow_storage_files(conf: Any) -> FileGenerator:
    yield Plugin(base_os=OS.WINDOWS,
                 source=Path("vss_shadow_storage.cmd"),
                 interval=conf.get("interval"))
register.bakery_plugin(
    name="vss_shadow_storage",
    files_function=get_vss_shadow_storage_files,
import re
from dataclasses import dataclass
from typing import Any, List, Mapping
from cmk.base.plugins.agent_based.agent_based_api.v1 import (
    register,
    Result,
    State,
    Service,
from .agent_based_api.v1.type_defs import CheckResult, DiscoveryResult, StringTable
@dataclass(frozen=True)
class VSSVolume:
    volume: str
    used_space: int
    allocated_space: int
    maximum_space: int
    used_percentage: int
    allocated_percentage: int
def convert_to_bytes(size: str) -> int:
    if size == "UNBOUNDED":
        return -1
    number, unit = size.split()
    number = float(number)
    units = {"KB": 1, "MB": 2, "GB": 3, "TB": 4}
    return int(number * 1024 ** units.get(unit, 0))
def parse_vss_data(string_table: StringTable) -> List[VSSVolume]:
    volumes = []
    for i in range(2, len(string_table), 6):
        if i + 5 >= len(string_table):
            break
        volume_line = " ".join(string_table[i + 1])
        used_line = " ".join(string_table[i + 3])
        allocated_line = " ".join(string_table[i + 4])
        maximum_line = " ".join(string_table[i + 5])
        volume = volume_line.split("(")[1].split(")")[0]
        used_space, used_percentage = used_line.split(": ")[1].split(" (")
        allocated_space, allocated_percentage = allocated_line.split(": ")[1].split(" (")
        maximum_space = maximum_line.split(": ")[1].split(" (")[0]
        volumes.append(VSSVolume(
            volume=volume,
            used_space=convert_to_bytes(used_space),
            allocated_space=convert_to_bytes(allocated_space),
            maximum_space=convert_to_bytes(maximum_space),
            used_percentage=int(used_percentage[:-2]),
            allocated_percentage=int(allocated_percentage[:-2]),
    return volumes
def discover_vss_volumes(params: Mapping[str, Any], section: List[VSSVolume]) -> DiscoveryResult:
    included_regex = re.compile(params.get('vss_volume_regex', '.*'))
    for volume in section:
        if included_regex.match(volume.volume):
            yield Service(item=volume.volume)
def check_vss_volumes(item: str, params: Mapping[str, Any], section: List[VSSVolume]) -> CheckResult:
    threshold_allocated_lower = params.get('threshold_allocated_lower', (0,))[0]
    threshold_allocated_upper = params.get('threshold_allocated_upper', (100,))[0]
    threshold_maximum_lower = params.get('threshold_maximum_lower', (0,))[0]
    threshold_maximum_upper = params.get('threshold_maximum_upper', (100,))[0]
    unbounded_handling = params.get('unbounded_handling', 'auto-detect')
        if volume.volume == item:
            summary = f"Used: {volume.used_space} bytes ({volume.used_percentage}%), Allocated: {volume.allocated_space} bytes ({volume.allocated_percentage}%), Maximum: {'UNBOUNDED' if volume.maximum_space == -1 else f'{volume.maximum_space} bytes'}"
            if volume.maximum_space == -1:
                yield Result(
                    state=State.UNKNOWN if unbounded_handling == 'unset' else State.CRIT,
                    summary=summary,
                    details=f"Maximum storage is UNBOUNDED and {unbounded_handling}"
            else:
                yield Result(state=State.OK, summary=summary, details="Maximum storage is BOUNDED")
            if volume.allocated_percentage < threshold_allocated_lower:
                yield Result(state=State.CRIT,
                             summary=f"Allocated space is below lower threshold: {volume.allocated_percentage}%")
            elif volume.allocated_percentage > threshold_allocated_upper:
                             summary=f"Allocated space is above upper threshold: {volume.allocated_percentage}%")
            if volume.maximum_space != -1:
                if volume.maximum_space < threshold_maximum_lower:
                                 summary=f"Maximum space is below lower threshold: {volume.maximum_space} bytes")
                elif volume.maximum_space > threshold_maximum_upper:
                                 summary=f"Maximum space is above upper threshold: {volume.maximum_space} bytes")
            yield Result(state=State.OK, summary=summary)
            return
    yield Result(state=State.UNKNOWN, summary=f"Volume {item} not found")
register.agent_section(
    parse_function=parse_vss_data,
register.check_plugin(
    sections=["vss_shadow_storage"],
    service_name="VSS Volume %s",
    discovery_function=discover_vss_volumes,
    check_function=check_vss_volumes,
    discovery_default_parameters={"vss_volume_regex": ".*"},
    check_default_parameters={
        "threshold_allocated_upper": (100,),
        "threshold_allocated_lower": (0,),
        "threshold_maximum_upper": (100,),
        "threshold_maximum_lower": (0,),
        "unbounded_handling": "set"
    discovery_ruleset_name="vss_shadow_storage",
from cmk.gui.i18n import _
from cmk.gui.plugins.metrics import metric_info
metric_info["vss_used_space"] = {
    "title": _("Used Shadow Copy Storage space"),
    "unit": "bytes",
    "color": "11/a",
metric_info["vss_allocated_space"] = {
    "title": _("Allocated Shadow Copy Storage space"),
    "unit": "bytes",
    "color": "22/a",
metric_info["vss_maximum_space"] = {
    "title": _("Maximum Shadow Copy Storage space"),
    "unit": "bytes",
    "color": "33/a",
metric_info["vss_used_percentage"] = {
    "title": _("Used Shadow Copy Storage space percentage"),
    "unit": "%",
    "color": "44/a",
metric_info["vss_allocated_percentage"] = {
    "title": _("Allocated Shadow Copy Storage space percentage"),
    "unit": "%",
    "color": "55/a",
from cmk.gui.cee.plugins.wato.agent_bakery.rulespecs.utils import RulespecGroupMonitoringAgentsAgentPlugins
from cmk.gui.plugins.wato import (
    rulespec_registry,
    HostRulespec,
from cmk.gui.valuespec import (
    Dictionary,
    DropdownChoice,
    Age
def _valuespec_agent_config_vss_volumes():
    return Dictionary(
        title=_("Shadow Copy Storage Monitoring (Windows)"),
        help=_("This will deploy the agent plugin <tt>vssadmin_volumes.cmd</tt> for monitoring."),
        elements=[("activated",
                   DropdownChoice(title=_("Windows VSS"),
                                  choices=[
                                      (True, _("Deploy plugin")),
                                      (None, _("Do not deploy plugin")),
                      "interval",
                      Age(
                          title=_("Run asynchronously"),
                          label=_("Interval for collecting data"),
                          default_value=3600,
rulespec_registry.register(
    HostRulespec(
        group=RulespecGroupMonitoringAgentsAgentPlugins,
        name="agent_config:vss_shadow_storage",
        valuespec=_valuespec_agent_config_vss_volumes,
    CheckParameterRulespecWithItem,
    rulespec_registry,
    RulespecGroupCheckParametersApplications,
    HostRulespec,
    RulespecGroupCheckParametersDiscovery
    Dictionary,
    Integer,
    TextAscii,
    Tuple,
    TextInput
def _parameter_valuespec_vss_volumes():
    return Dictionary(elements=[
        ("threshold_allocated_upper",
         Tuple(
             title=_("Upper threshold for allocated space percentage"),
             elements=[
                 Integer(title=_("Warning at"), unit="%"),
                 Integer(title=_("Critical at"), unit="%"),
        ("threshold_allocated_lower",
         Tuple(
             title=_("Lower threshold for allocated space percentage"),
             elements=[
                 Integer(title=_("Warning below"), unit="%"),
                 Integer(title=_("Critical below"), unit="%"),
        ("threshold_maximum_upper",
         Tuple(
             title=_("Upper threshold for maximum space"),
             elements=[
                 Integer(title=_("Warning at"), unit="bytes"),
                 Integer(title=_("Critical at"), unit="bytes"),
        ("threshold_maximum_lower",
         Tuple(
             title=_("Lower threshold for maximum space"),
             elements=[
                 Integer(title=_("Warning below"), unit="bytes"),
                 Integer(title=_("Critical below"), unit="bytes"),
        ("unbounded_handling",
         TextAscii(
             title=_("Handling of unbounded storage"),
             help=_("Specify how to handle unbounded storage: 'unset', 'set', or 'auto-detect'.")
    CheckParameterRulespecWithItem(
        check_group_name="vss_shadow_storage",
        group=RulespecGroupCheckParametersApplications,
        item_spec=lambda: TextAscii(title=_("Volume name")),
        match_type="dict",
        parameter_valuespec=_parameter_valuespec_vss_volumes,
        title=lambda: _("VSS Shadow Storage"),
def _valuespec_vss_shadow_storage_inventory():
    return Dictionary(
        title=_("VSS shadow storage discovery"),
        help=_("This selects which VSS volumes are discovered."),
        elements=[
                "vss_volume_regex",
                TextInput(
                    title=_("Filter relevant VSS volumes by regex"),
                    help=_(
                        " You can provide filtering against a specific regex you are"
                        " interested in. This is to only catch volumes of interest."
    HostRulespec(
        group=RulespecGroupCheckParametersDiscovery,
        name="vss_shadow_storage_inventory",
        valuespec=_valuespec_vss_shadow_storage_inventory,
There is a naming mismatch (vss_shadow_storage_inventory)
