Hello !
I’m trying to get warned when a WARN or CRITICAL level of temperature is reached by a machine.
I tried 2 ways :
1/ Creating an [IPMI Sensor Summary] , but I get the number of Sensors OK as status, the Temperature is used as Service Perf-O-Meter/Metrics/Graphs . But I cannot manage to add any WARN/CRIT rule based on the Temperature ! It seems to concern only the number of sensors…
2/ Creating an [IPMI Sensors] with a rule to get one service discovered for each sensor. It seemed to be the good way : the Temperature values are actualy shown, BUT then : the value can’t be converted as a double float because a string "status OK " is shown as a prefix to the temperature value… => no graphs, and no WARN/CRIT level can be set !
Is there anyone who managed with these Temperatures (or whatever similar IPMI sensor) and associated alerts ?!?
Thank you
check_mk release 2.0.0p4 (CRE)
host temperature to check under linux
