IPMI Sensors via Freeipmi or IPMItool - Chassis Intru Sensor is missing
CMK version: 2.3.0p6
OS version: Ubuntu 20.04
When I use the deprecated “Management board” in Host Configuration, I get the IPMI Sensor with the “Chassis Intru” Sensor included:
Management Interface: IPMI Sensor CPU_Temp Status: OK, 49.00 °C
Management Interface: IPMI Sensor Chassis_Intru Status: OK
Management Interface: IPMI Sensor FAN3 Status: OK, 4480.00 RPM
However, with the new check “IPMI Sensors via Freeipmi or IPMItool,” the “Chassis Intru” Sensor is missing:
IPMI Sensor CPU_Temp Status: ok, 49.00 degrees_C
IPMI Sensor FAN3 Status: ok, 4480.00 RPM
What can I do to include the “Chassis Intru” Sensor with the new check?
