Is it possible to define a hook after clicking bake agent
Hello
I would like to know if there is a way to define a hook when we click on GUI bake and sign (or bake) agents
I would like to build a script which upload automatically signed checkmk agents to our private registry and therfore would need to konw if it is possible.
Thanks
sebastien
We have a similar need but Checkmk does not have any web hooks, or message bus or anything close.
However if I recall correctly there is state file for agent bakery. I’m thinking about reading the state and use it to push artefacts.
Personally, I find this idea really interesting. Would you mind suggesting it in the ideas portal? https://ideas.checkmk.com/
Interesting idea, that would be cool!
But couldn’t you just sync the ~/var/check_mk/agents/ directory to your registry? All the baked agents are stored there.
Hello, It’s done
In the meantime I will try to using status file.
Thanks and regards
sebastien
That could be a possibility. but I have to dispatch them in different folder.
Thanks, I will have a look to this state file as a start.
