Error message: This service is based on cached agent data and cannot be rescheduled. Cache generated 100 s ago, cache interval: 90 s, elapsed cache lifespan: 111%
Is there a way to disable cache for certain types of local check? This particular check uses piggyback feature. The check itself is a shell script.
I need the check to not rely on cached data as I am actively making changes the check script and would like to test without any caching at play.
This is a local check stored in /usr/lib/check_mk_agent/plugins/mycheck.sh
The fact that the local check is stored there and not in /usr/lib/check_mk_agent/plugins/90/mycheck.sh
gives me the idea that it is a config thing.
You can also check the /etc/checkmk/ folder on the host for config files/entries.
