I’m trying to integrate Checkmk (1.6.0p8) with Jira (8.4.1). Notification settings in Checkmk are configured according to the manual but notifictions are failing with the output:
Unable to query custom field search, JIRA response code 400, The operator '=' is not supported by the 'cf[14902]' field.Unverified HTTPS request warnings are ignored. Use with caution.
Customfields have been created as regular text fields, as manual says. Did any of you have a similar problem? Thanks for any advice.
Regards,
Pawel
