Hi all,
I have a checkmk instance that is to create and close tickets in JIRA. Creation works fine, and accordign to (Notifications via Jira) I can set a resolution once the service is up again.
Unfortunately it seems that I can only set a status, not a resolution. Even the given samples are status entries (“To Do”; “In Progress”, “Done”).
Is there a way to set the resolution as well? Entering the “Resolution ID” as described here (how to get resolution id for my list of resolution...) gives an error message in checkmk:
Unable to resolve […] JIRA response code 500, Interner ServerfehlerUnverified HTTPS request warnings are ignored. Use with caution.
I assume the resolution and status are different DB tables and the JIRA plugin uses the status table.
Any ideas?
Thanks,
Boas
