Jira Notification Issue
CMK version: 1.6.4
OS version: [2.2.0p5.cee]
We have migrated to 2.2 version, but the Jira notification has stopped working. I have gone through the notify logs but couldn’t understand what’s wrong.
Please help.
You want to look at $OMD_ROOT/var/log/mknotifyd.log. That should contain errors in sending the notification. The screenshot only shows the matching logic.
Also, you might want to check, if you put a custom version of the notification plugin in the $OMD_ROOT/local/ structure.
Hi Robin,
I was following the official document.
mknotifyd.log is empty and there’s mknotifyd.log.1 containing the last Jira notification before the migration to new version. I am not sure why I need to put a custom version of notification plugin as it was working perfectly before the migration.
It’s working now again.
Thank you.
Can you share, what caused the problem, so others can find the solution qickly? Thanks!
I didn’t change anything. I re-configured the same thing again and it started working again.
