CMK version:
2.2.0.11p OS version:
Appliance, 1.6.5
2023-10-11 12:14:25,076 [20] [cmk.utils.notify] sending command LOG;SERVICE NOTIFICATION RESULT: xxxxxxxxx;p80-prod-cmk02;Check_MK;CRITICAL;jira_issues;Unable to query custom field search, JIRA response code 400, Field ‘cf[10065]’ does not exist or this field cannot be viewed by anonymous users.;Unable to query custom field search, JIRA response code 400, Field ‘cf[10065]’ does not exist or this field cannot be viewed by anonymous users.
When I use the regular password for my user that i use to connect with JIRA, i get the error above.
when I create an API token and use that as the password, I don’t get any issues but the JIRA issue is not created.
the custom fields both exist and are connected to the create screen and issue page.
as described in the checkmk guidelines they have the Number field format.
I thought it had to do with access, but can confirm the user which credentials I used, can create issues manually.
I have tested some more. When i use my password, I get the error in my first post. When I use an API-token, I get error:
One faster way to confirm if its not an access would be to pickup a working JIRA POST example and try doig a POST request manually with something like curl and see if you hit the same error.
