What I figured out is:
I can access both cluster I try to monitor using curl and api calls…
Both cluster are sending information for example to api2/json/nodes:
A) Working cluster in cmk
curl --insecure --cookie "$(<cookie)" https://10.1.0.11:8006/api2/json/nodes/
{"data":[{"maxdisk":72917082112,"level":"","uptime":1737838,"ssl_fingerprint":"40:FB:1F:BC:AF:84:AD:17:00:8E:1F:6E:C6:D4:4E:ED:76:EE:53:E4:00:77:46:51:10:CF:1C:FD:BA:B4:CC:56","node":"pve11","maxmem":202792255488,"cpu":0.0392048424043194,"mem":106509987840,"status":"online","id":"node/pve11","maxcpu":24,"type":"node","disk":6425444352},{"id":"node/pve13","status":"online","mem":110634098688,"cpu":0.0325383434460698,"disk":12424396800,"type":"node","maxcpu":24,"level":"","maxdisk":72917082112,"maxmem":202792255488,"ssl_fingerprint":"2B:AA:33:BF:4B:F1:6B:E2:11:38:CF:6F:7C:15:0B:E4:45:80:D6:22:B1:3C:DD:23:11:88:F0:F8:98:DC:C3:3D","node":"pve13","uptime":1742170},{"node":"pve12","ssl_fingerprint":"F8:BD:F6:E5:7B:A2:B1:66:D4:94:79:6D:BB:31:E0:EA:03:0E:A4:1F:28:67:CF:22:5F:19:A0:B9:3A:D5:7D:3D","uptime":1740224,"maxmem":202792366080,"maxdisk":72917082112,"level":"","type":"node","maxcpu":12,"disk":6132224000,"mem":89475149824,"status":"online","id":"node/pve12","cpu":0.081519469246617}]}
B) And also the ,not working" cluster… Unhandled exception: JSONDecodeError(‘Expecting value: line 1 column 1 (char 0)’)
curl --insecure --cookie "$(<cookie)" https://192.168.120.143:8006/api2/json/nodes/
{"data":[{"id":"node/pve145","ssl_fingerprint":"0F:E8:73:9C:42:8C:77:4B:54:48:03:B8:F5:16:0F:A0:52:5B:83:70:AD:BB:E8:2A:E1:59:34:53:EC:91:DD:76","status":"offline","node":"pve145","type":"node"},{"status":"online","cpu":0.0321348301827427,"node":"pve149","ssl_fingerprint":"D7:DA:28:8F:8C:88:28:B6:78:98:20:8F:03:8A:8D:8E:10:2A:75:AF:50:30:4F:D7:08:3F:61:F5:CF:41:FC:DB","uptime":946312,"maxdisk":72917082112,"level":"","maxmem":135146557440,"mem":64010133504,"type":"node","id":"node/pve149","disk":13713842176,"maxcpu":32},{"status":"offline","ssl_fingerprint":"02:BB:D6:A7:D1:C7:22:C8:D2:25:E2:78:5D:B9:4A:AF:D0:FE:57:28:3A:2B:A6:9D:2C:06:DA:39:71:A9:69:24","node":"pve152","type":"node","id":"node/pve152"},{"id":"node/pve147","node":"pve147","type":"node","ssl_fingerprint":"04:5D:D2:CD:F8:5F:06:2A:C0:59:A5:D8:57:88:5C:92:B1:00:49:D2:9B:5A:00:F7:2C:B4:E2:59:83:6E:63:FC","status":"offline"},{"id":"node/pve153","status":"offline","ssl_fingerprint":"03:CE:88:96:06:24:62:DE:A8:B4:F4:36:60:68:01:20:55:67:94:A4:3F:13:03:AC:24:C5:62:DE:3E:B6:D5:B6","node":"pve153","type":"node"},{"ssl_fingerprint":"11:2A:F7:23:E4:21:51:A1:10:05:56:EF:1B:70:82:30:40:8F:49:32:3B:1D:F9:5D:21:C7:09:48:08:CC:81:D4","status":"offline","type":"node","node":"pve151","id":"node/pve151"},{"ssl_fingerprint":"BC:89:C2:31:76:C0:DD:97:A7:58:0C:39:24:5D:BC:62:D0:60:70:7F:8B:45:96:70:AF:FB:61:5C:67:52:47:9B","node":"pve144","maxdisk":17568661504,"uptime":944280,"level":"","maxmem":126724317184,"status":"online","cpu":0.0692345936366371,"disk":7880556544,"id":"node/pve144","maxcpu":16,"mem":69064015872,"type":"node"},{"type":"node","mem":57873694720,"maxcpu":32,"disk":5036539904,"id":"node/pve143","status":"online","cpu":0.0502879591951435,"node":"pve143","ssl_fingerprint":"05:A8:75:94:60:CB:0B:AF:76:8D:B5:94:00:B7:E9:C6:2F:45:49:34:7A:13:E8:03:78:19:87:81:55:FC:A5:28","maxmem":160513699840,"level":"","uptime":1584794,"maxdisk":72917082112}]}
Any hints how to debug the problem further?
Regards Lukas
