Hello everyone,
We’re new to the Checkmk family. I’m trying to demonstrate it’s capabilities to my infrastructure team, so far so good. We are a Juniper shop and I’m having trouble with one of the more important checks: chassis or system alarms. I can’t seem to get the service discovery to pick them up. We are using SNMP v2. I’ve tested it against all of our EX models and varying versions of Junos. None seem to work. Other things like CPU, fans, PSUs, etc. work great. Has anyone encountered this before or have any insight? Thank you!
CMK version:
2.0.0p22 (CRE)
OS version:
AlmaLinux 8.5
Service discovery against Juniper switches does not appear to detect chassis alarms (juniper_alarm)
This was run against a Juniper EX2200-C-12P switch running Junos 15.1R5.5 with a known active chassis alarm.
Checkmk version 2.0.0p22
Trying to acquire lock on /omd/sites/prod/var/check_mk/license_usage/next_run
Got lock on /omd/sites/prod/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/prod/var/check_mk/license_usage/history.json
Got lock on /omd/sites/prod/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/prod/var/check_mk/license_usage/history.json
Released lock on /omd/sites/prod/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/prod/var/check_mk/license_usage/next_run
Released lock on /omd/sites/prod/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/prod/var/check_mk/autochecks/<host_name>.mk
+ FETCHING DATA
[cpu_tracking] Start [7f2dd4581070]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/prod/tmp/check_mk/data_source_cache/snmp/<host_name>'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 49 sec, allowed is 0 sec)
No persisted sections loaded
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running 'snmpget -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.1.0'
SNMP answer: ==> ["Juniper Networks, Inc. ex2200-c-12p-2g Ethernet Switch, kernel JUNOS 15.1R5.5, Build date: 2016-11-25 16:56:53 UTC Copyright (c) 1996-2016 Juniper Networks, Inc."]
b'Juniper Networks, Inc. ex2200-c-12p-2g Ethernet Switch, kernel JUNOS 15.1R5.5, Build date: 2016-11-25 16:56:53 UTC Copyright (c) 1996-2016 Juniper Networks, Inc.'
Getting OID .1.3.6.1.2.1.1.2.0: Running 'snmpget -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.2.0'
SNMP answer: ==> [.1.3.6.1.4.1.2636.1.1.1.2.43]
b'.1.3.6.1.4.1.2636.1.1.1.2.43'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.2636.1.1.1.2.43'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Juniper Networks, Inc. ex2200-c-12p-2g Ethernet Switch, kernel JUNOS 15.1R5.5, Build date: 2016-11-25 16:56:53 UTC Copyright (c) 1996-2016 Juniper Networks, Inc.'
Getting OID .1.3.6.1.4.1.232.2.2.4.2.0: Running 'snmpget -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.4.1.232.2.2.4.2.0'
SNMP answer: ==> [No Such Object available on this agent at this OID]
failed.
Getting OID .1.3.6.1.4.1.674.*: Running 'snmpgetnext -Cf -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.4.1.674'
SNMP answer: ==> [.1.3.6.1.4.1.2636.1.1.1.1.43.0]
failed.
Using cached OID .1.3.6.1.4.1.232.2.2.4.2.0: None
Getting OID .1.3.6.1.2.1.47.1.1.1.1.*: Running 'snmpgetnext -Cf -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1'
SNMP answer: ==> ["Juniper EX2200-C-12P-2G, POE+ Ethernet Switch"]
b'Juniper EX2200-C-12P-2G, POE+ Ethernet Switch'
Getting OID .1.3.6.1.4.1.2036.2.1.1.4.0: Running 'snmpget -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2036.2.1.1.4.0'
failed.
Getting OID .1.3.6.1.2.1.2.2.1.*: Running 'snmpgetnext -Cf -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -On -OQ -Oe -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1'
SNMP answer: ==> [4]
b'4'
SNMP scan found hr_mem inv_if juniper_info snmp_extended_info snmp_os snmp_uptime
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/snmp_scan_cache/<host_name>.xxx.xx.xx.xx
Got lock on /omd/sites/prod/tmp/check_mk/snmp_scan_cache/<host_name>.xxx.xx.xx.xx
Releasing lock on /omd/sites/prod/tmp/check_mk/snmp_scan_cache/<host_name>.xxx.xx.xx.xx
Released lock on /omd/sites/prod/tmp/check_mk/snmp_scan_cache/<host_name>.xxx.xx.xx.xx
juniper_cpu_util: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.13.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.13.1.8'
hr_fs: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.2.3.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.2.3.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.2.3.1.4'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.2.3.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.2.3.1.6'
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.2
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.3
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.4
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.5
Already fetched OID: .1.3.6.1.2.1.25.2.3.1.6
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.1'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.8'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.9'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.14'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.19'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.20'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.21'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.18'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.31.1.1.1.15'
inv_if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Already fetched OID: .1.3.6.1.2.1.2.2.1.1
Already fetched OID: .1.3.6.1.2.1.2.2.1.2
Already fetched OID: .1.3.6.1.2.1.31.1.1.1.18
Already fetched OID: .1.3.6.1.2.1.2.2.1.3
Already fetched OID: .1.3.6.1.2.1.2.2.1.5
Already fetched OID: .1.3.6.1.2.1.31.1.1.1.15
Already fetched OID: .1.3.6.1.2.1.2.2.1.8
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.7'
Already fetched OID: .1.3.6.1.2.1.2.2.1.6
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.2.2.1.9'
juniper_fru: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.15.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.15.1.6'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.15.1.8'
juniper_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.3'
juniper_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.13.1.5.9'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.4.1.2636.3.1.13.1.11.9'
pse_poe: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.105.1.3.1.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.105.1.3.1.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.105.1.3.1.1.4'
snmp_extended_info: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.2'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.4'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.7'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.10'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.11'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.12'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.47.1.1.1.1.13'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.1'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.4'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.5'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.6'
snmp_os: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.1.0'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.2.0'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.3.0'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.5.0'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.1.3'
Running 'snmpbulkwalk -Cr10 -v2c -c <community_string> -m "" -M "" -t 60.00 -r 3 -Cc -OQ -OU -On -Ot xxx.xx.xx.xx .1.3.6.1.2.1.25.1.1'
Write data to cache file /omd/sites/prod/tmp/check_mk/data_source_cache/snmp/checking/<host_name>
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/data_source_cache/snmp/checking/<host_name>
Got lock on /omd/sites/prod/tmp/check_mk/data_source_cache/snmp/checking/<host_name>
Releasing lock on /omd/sites/prod/tmp/check_mk/data_source_cache/snmp/checking/<host_name>
Released lock on /omd/sites/prod/tmp/check_mk/data_source_cache/snmp/checking/<host_name>
[cpu_tracking] Stop [7f2dd4581070 - Snapshot(process=posix.times_result(user=0.08999999999999986, system=0.19999999999999998, children_user=0.07, children_system=0.26, elapsed=24.809999999590218))]
[cpu_tracking] Start [7f2dd44f3ac0]
No piggyback files for '<host_name>'. Skip processing.
No piggyback files for 'xxx.xx.xx.xx'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/prod/tmp/check_mk/data_source_cache/piggyback/<host_name>'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f2dd44f3ac0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
[cpu_tracking] Start [7f2dd4738b50]
+ PARSE FETCHER RESULTS
-> Add sections: ['hr_fs', 'hr_mem', 'if64', 'inv_if', 'juniper_cpu_util', 'juniper_fru', 'juniper_info', 'juniper_mem', 'pse_poe', 'snmp_extended_info', 'snmp_info', 'snmp_os', 'snmp_uptime']
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/counters/<host_name>
Got lock on /omd/sites/prod/tmp/check_mk/counters/<host_name>
Releasing lock on /omd/sites/prod/tmp/check_mk/counters/<host_name>
Released lock on /omd/sites/prod/tmp/check_mk/counters/<host_name>
CPU utilization Routing Engine 0 Total CPU: 6.00%
Filesystem /config 0.57% used (362.00 kB of 61.85 MB, warn/crit at 50.00%/68.08%), trend: 0.00 B / 24 hours
Filesystem /var/tmp 4.48% used (16.54 of 368.97 MB, warn/crit at 55.34%/77.67%), trend: 0.00 B / 24 hours
Interface ge-0/1/0 [vma-c1.net trunk], (up), MAC: 84:B5:9C:46:09:8F, Speed: 1 GBit/s, In: 1.11 kB/s (<0.01%), Out: 2.61 kB/s (<0.01%)
Memory Routing Engine 0 70% used
POE1 consumption POE usage (2W/100W): : 2.0%
Power Supply FRU 0 0/0 Operational status: online
SNMP Info Juniper Networks, Inc. ex2200-c-12p-2g Ethernet Switch, kernel JUNOS 15.1R5.5, Build date: 2016-11-25 16:56:53 UTC Copyright (c) 1996-2016 Juniper Networks, Inc., <host_name>, , Student Life Technology Services 292-5700
Uptime Up since Jan 08 2022 09:17:55, Uptime: 94 days 0 hours
+ EXECUTING INVENTORY PLUGINS
hp_proliant_mem: skipped (no data)
ipmi_firmware: skipped (no data)
inventory_checkmk: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
inventory_oracle_tablespaces: skipped (no data)
dmidecode: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
juniper_info: ok
juniper_info: skipped (no data)
mem_used: skipped (no data)
snmp_info: ok
snmp_info: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
allnet_ip_sensoric: skipped (no data)
aruba_wlc_aps: skipped (no data)
check_mk: skipped (no data)
checkpoint_inv_tunnels: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_container_node_name: skipped (no data)
docker_node_images: skipped (no data)
docker_node_info: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_job_container: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_roles: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_if: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_uname: skipped (no data)
lnx_video: skipped (no data)
lparstat_aix: skipped (no data)
mssql_clusters: skipped (no data)
mssql_versions: skipped (no data)
netapp_api_disk: skipped (no data)
netapp_api_info: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_systemparameter: skipped (no data)
perle_chassis: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
prtconf: skipped (no data)
snmp_extended_info: ok
snmp_extended_info: skipped (no data)
snmp_os: ok
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_routes: skipped (no data)
solaris_uname: skipped (no data)
statgrab_net: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_os: skipped (no data)
win_reg_uninstall: skipped (no data)
win_system: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
winperf_if: skipped (no data)
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>
Got lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>
Releasing lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>
Released lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>.gz
Got lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>.gz
Releasing lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>.gz
Released lock on /omd/sites/prod/tmp/check_mk/status_data/<host_name>.gz
Trying to acquire lock on /omd/sites/prod/tmp/check_mk/status_data/.last
Got lock on /omd/sites/prod/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/prod/tmp/check_mk/status_data/.last
Released lock on /omd/sites/prod/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7f2dd4738b50 - Snapshot(process=posix.times_result(user=0.030000000000000027, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03000000026077032))]
[snmp] Success, execution time 24.8 sec | execution_time=24.850 user_time=0.120 system_time=0.200 children_user_time=0.070 children_system_time=0.260 cmk_time_snmp=24.190 cmk_time_agent=0.010
