Juniper EX4200 POE consumption Issue
Good Day All
I am in the process of getting all my Devices into Check_MK CRE and I can the see the following on one of my Juniper EX4200 Switches (It shows POE Usage of 8132%):
Has anyone else come across something similar and if so how did you rectify it?
CMK Version: Checkmk Raw Edition 2.1.0
There is no easy solution as Juniper is one of some manufacturers that are not correctly implement the POE MIB. The shown value here is in Milliwatt and the MIB definition says it should be Watt. I extended the check a little bit that every Value higher than 1000 is divided by 1000 to normal values.
I know that’s an ugly work around but i don’t know of a nice solution as the MIB is no multiplication factor or anything like this.
So basically there is no real solution and Juniper wont talk nicely to Check>Mk?
Yes, same issue here on EX3300. Switch is at 0.8% and CheckMK says is 80% and CRIT
There is a solution.
Copy the file pse_poe from “~/share/check_mk/checks/” to “~/local/share/check_mk/checks/” and modify it the following way.
Original
def parse_pse_poe(info):
    parse info data and create dictionary with namedtuples for each OID.
       oid_end : PoeValues(poe_max, poe_used, poe_status, poe_status_detail)
    :param info: parsed snmp data
    :return: dictionary
    poe_dict = {}
    for oid_end, poe_max, pse_op_status, poe_used in info:
        poe_dict[str(oid_end)] = PoeValues(poe_max=int(poe_max),
                                           poe_used=int(poe_used),
                                           poe_status=int(pse_op_status),
                                           poe_status_detail=None)
    return poe_dict
modified version
    :return: dictionary
    poe_dict = {}
        if int(poe_used) >= 1000:
            used_poe = int(poe_used) / 1000
        else:
                                           poe_used=used_poe,
    return poe_dict
If i made no mistake this should work. :smiley:
