Juniper SRX 100Gb interfaces reporting errors erroneously - not in junos show interface
CMK version:
2.1.0 and 2.2.0
OS version:
RHEL8
We recently upgraded our SRX from 20.4 to 21.4 and started reporting errors on the 100Gb “et-*” interfaces. These errors are not reflected in the “show interface detail”
c1u19fwl-node0> show interfaces et-1/0/0 detail
Physical interface: et-1/0/0, Enabled, Physical link is Up
Interface index: 157, SNMP ifIndex: 516, Generation: 160
Link-level type: Ethernet, MTU: 9192, MRU: 9200, Speed: 100Gbps, BPDU Error: None, Loop Detect PDU Error: None, Ethernet-Switching Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Disabled
Device flags : Present Running
Interface flags: SNMP-Traps Internal: 0x4000
CoS queues : 8 supported, 8 maximum usable queues
Schedulers : 0
Hold-times : Up 0 ms, Down 0 ms
Current address: 00:10:db:ff:10:01, Hardware address: 24:fc:4e:49:96:1c
Last flapped : 2023-11-02 18:42:53 UTC (00:36:27 ago)
Statistics last cleared: Never
Traffic statistics:
Input bytes : 368998 856 bps
Output bytes : 32548 0 bps
Input packets: 3365 0 pps
Output packets: 158 0 pps
Egress queues: 8 supported, 4 in use
Queue counters: Queued packets Transmitted packets Dropped packets
0 0 0 0
1 0 0 0
2 0 0 0
3 158 158 0
Queue number: Mapped forwarding classes
0 best-effort
1 expedited-forwarding
2 assured-forwarding
3 network-control
Active alarms : None
Active defects : None
PCS statistics Seconds
Bit errors 0
Errored blocks 0
Ethernet FEC Mode : FEC91
Ethernet FEC statistics Errors
FEC Corrected Errors 0
FEC Uncorrected Errors 0
FEC Corrected Errors Rate 0
FEC Uncorrected Errors Rate 0
Preclassifier statistics:
Traffic Class Received Packets Transmitted Packets Dropped Packets
real-time 0 0 0
network-control 3282 3282 0
best-effort 124 124 0
Interface transmit statistics: Disabled
I think this might be bug in junos 21.4… When I snmpwalk device 516 I get
IF-MIB::ifInErrors.516 = Counter32: 52
but that is not reflected in the show interface detail
