If I try to modify the JVM Memory Level to get rid of false Warnings, this doesn’t work anymore. You may try to modify the value , save and exit to the Rules folder (see pic below) and the value shows “no parameter” > reopen the Rule and everything is back to factory i.E. empty. I checked this with percentage values only.
Am I the only one seeing this behavior ?
Problem has been fixed with latest Update 2.0.0p5
- 12880 FIX: Fix ruleset “JVM memory levels”
Thankx
