I have two servers running keepalived. They have checkMK agent 200p13 installed and discovered all services including mysql.
I created two service monitoring rules for each to monitor for keepalived. Check mk still does not discover the service.
If I create the rule for Enforced services, I get “UNKN VRRP Instance 192.168.10.90 Check plugin received no monitoring data” in the service configuration.
Edit: I see traffic to port 161 being blocked by IPtables. That’s SNMP. Do I need SNMP running for that check? I would like to have only Check MK running, no SNMP.
Ok I tried that, but I could not use it. I already have a notify script running for maxscale and thus I tried to adapt the approach in the link to that situation. Another issue is, that keepalived complains if the scripts are “insecure”, means ran by root and insecure scripts setting is off (which should).
I tried to call the notify script from the other notify script that already runs for maxscale
But since the script is running not as root, it can not write into /run/ so I changed the script to write into /tmp/ which it does.
-rw------- 1 keepalived_script keepalived_script 13 Dec 15 10:55 keepalived.VI_1.BACKUP.state
-rw------- 1 keepalived_script keepalived_script 13 Dec 15 10:55 keepalived.VI_1.MASTER.state
-rw------- 1 keepalived_script keepalived_script 11 Dec 15 10:55 keepalived.VI_1.STOP.state
Then tried to change the path in the perl script to read from /tmp/ instead of /var/run.
for my $file (</tmp/keepalived.*.*.state>) {
open(IN, $file) || next;
But that does not work either, it (the perl script) is not returning anything and check_mk still does not discover. I tried that by running it manually.
In your script, a variable got lost. The invocation should look like
/etc/keepalived/keepalived_notify $1 $2 $3
The script contains, besides comments, only one line of code. You can easily insert that line to the beginning of your other notification script.
I would not put the state files into a world writable directory like /tmp, as this makes your system vulnerable to symlink attacks. If it runs under a different UID than root, you’d better create a separate directory like /var/local/keepalived where only the keepalived notify script user has write permissions.
Ok I thought it only needs $2 and $3 because that’s what is in the filename. Understand it now. Yeah the /tmp/ was just for testing because everyone can write there.
