Hello all,
we upgraded our Checkmk Server from 1.5.0p24 to 1.6.0p19. Since then our SSO with Kerberos is not working anymore, because (I think this is the problem) I always get a 302 – Found instead of a 401 – Unauthorized, so the client will not do any authentication attempt. I checked this by setting the LogLevel of the site-apache to trace8.
On the 1.5.0 version the configuration from the Checkmk manual is working (with some fixes due to missing lines in the auth.conf example). I only had to delete the cookie_auth.conf file (what is this for?), then SSO was working fine.
On the 1.6.0 version I still have problems to do this. If I deny access to the login.py file then SSO was working, unfortunately I got still some 302 redirects. But then login without SSO is not possible.
Maybe someone has SSO with Kerberos and the 1.6.0 running and can help me. Or can provide me his working configuration.
Thanks!
