CMK version: 2.2.0p12
OS version: Ubuntu 22.10
Error message: Container Metrics: No data(No container metrics were collected from the cluster collector )CRIT
PU resources Requests: 0.000 (0/2 containers with requests), Limits: 0.000 (0/2 containers with limits), Allocatable: 0.000
Cluster collector Cluster collector version: 1.5.0, Nodes with container collectors: 1/1, Nodes with machine collectors: 1/1, Container Metrics: No data(!!), Machine Metrics: OK
Info Name: kube
Kubernetes API Live, Ready
Memory resources Requests: 0 B (0/2 containers with requests), Limits: 0 B (0/2 containers with limits), Allocatable: 0 B
Nodes No worker nodes found, Control plane nodes 1/1
Pod resources Running: 0, Pending: 1, Succeeded: 0, Failed: 0, Unknown: 0, Allocatable: 0
I will try to get some Monitoring Data from my Kubernetes Cluster. (K3S - Single Node Cluster / Server Version: v1.27.2+k3s1).
The Helm Release 1.5.0 has been successfully installed and i will get all deployments, pods, services, etc. All will work fine.
But no Metric Data can be found.
Is this maybe a problem with the kubernetes version, or while i’m using k3s instead k8s ?
The Debug output will only show not really an error.
Is there any other point where i can check ?
Kind regards
Michél
