Steven1
(Steven)
September 12, 2025, 2:49pm
1
2.3.0p36 (RAW)
OS Ubuntu 24.04 LTS
Everyday I see disks merged which is to be expected with Kubernetes, but I don’t want to have to add or ignore it everyday. Is there a way to make them not discover but keep all the rest of the monitoring normal as before?
I found the “Disabled Services” option and created a new rule like below:
“Filesystem /var/lib/containers/storage/overlay/.*”
But the CheckMK_Discoveries still keep coming and I don’t understand why.
Can someone shed a light on what I might be missing?
mike1098
(Michael FRANK)
September 15, 2025, 8:15am
2
Basically the discovery happens before the disabled services can act. A quick look at the FS discovery rule show me that there is no way to exclude FS from discovery, so disabled services is the only way AFAIK.
We have a similar problem covered the same way as you did and its working. The worth thing is that we have over 240 disabled services many of them tagged with ‘Item not found in monitoring data’. There must be a better solution via discovery.
Did you activate changes?
You should see the disabled in the service discovery:
regards
Mike
mike1098
(Michael FRANK)
September 15, 2025, 8:18am
3
Can you share the FS section from Agent output? This way I can simulate.
thanks
Mike
Steven1
(Steven)
September 15, 2025, 8:29am
4
I do activate the changes of course
This is the full output from the Agent
<<<check_mk>>>
Version: 2.3.0p26
AgentOS: linux
Hostname: wn01
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
OSType: linux
OSName: Ubuntu
OSVersion: 24.04
OSPlatform: ubuntu
FailedPythonReason:
SSHClient:
<<<cmk_agent_ctl_status:sep(0)>>>
{“version”:“2.3.0p26”,“agent_socket_operational”:true,“ip_allowlist”: ,“allow_legacy_pull”:true,“connections”: }
<<<checkmk_agent_plugins_lnx:sep(0)>>>
pluginsdir /usr/lib/check_mk_agent/plugins
localdir /usr/lib/check_mk_agent/local
<<labels:sep(0) >>
{“cmk/device_type”:“vm”}
<<<df_v2>>>
tmpfs tmpfs 813140 4812 808328 1% /run
efivarfs efivarfs 256 63 189 25% /sys/firmware/efi/efivars
/dev/mapper/ubuntu–vg-ubuntu–lv ext4 151337312 24762932 119890104 18% /
tmpfs tmpfs 4065696 0 4065696 0% /dev/shm
tmpfs tmpfs 5120 0 5120 0% /run/lock
/dev/sdb2 ext4 1992552 197604 1673708 11% /boot
/dev/sdb1 vfat 1098628 6288 1092340 1% /boot/efi
tmpfs tmpfs 512000 1052 510948 1% /var/lib/kubelet/pods/5d07b854-99fe-41a9-b099-b1bd7c0ac93d/volumes/kubernetes.io~empty-dir/dshm
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/9cbcb159-7012-4688-b4e7-713b435c1d1a/volumes/kubernetes.io~projected/kube-api-access-bt5bt
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/f908c391-082e-45bd-8a63-b733cc331586/volumes/kubernetes.io~projected/kube-api-access-8clxl
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/938d752d-12d9-4a25-9b99-352e3e34c009/volumes/kubernetes.io~projected/kube-api-access-6gb5j
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/c9e3dd75-ecb3-4ff2-acc2-f7a73ea1967b/volumes/kubernetes.io~projected/kube-api-access-zd7r4
tmpfs tmpfs 204800 12 204788 1% /var/lib/kubelet/pods/f62975d9-119e-480f-8fbd-b9b482b6cf7a/volumes/kubernetes.io~projected/kube-api-access-mvhrh
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/b2df587a-0375-49ab-a153-ebe4e2541aab/volumes/kubernetes.io~projected/kube-api-access-255qd
tmpfs tmpfs 524288 12 524276 1% /var/lib/kubelet/pods/47cecfa6-d753-44e8-9016-2314b7bdbd03/volumes/kubernetes.io~projected/kube-api-access-p27jm
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/c76796c7-855e-46e4-a3bc-7b063052001d/volumes/kubernetes.io~projected/kube-api-access-n99sm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/1e7369d59187ba86d6b775a4c60dd526e739e43a004f4a877ae39235e5f04ba5/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/3787dd3a98f49756987a24cae35a15c0bb0aa77385465fc9c19df8f32921209d/merged
tmpfs tmpfs 512000 12 511988 1% /var/lib/kubelet/pods/5d07b854-99fe-41a9-b099-b1bd7c0ac93d/volumes/kubernetes.io~projected/kube-api-access-blmxh
tmpfs tmpfs 8028992 4 8028988 1% /var/lib/kubelet/pods/29b829f1-60f1-448d-9db3-f1d74411569d/volumes/kubernetes.io~secret/memberlist
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/29b829f1-60f1-448d-9db3-f1d74411569d/volumes/kubernetes.io~projected/kube-api-access-lftjm
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/7409c6f7-07be-463a-a34d-ed11f4dc18a1/volumes/kubernetes.io~projected/kube-api-access-r8bxw
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/0a1c257a-d21b-41e0-b5db-9d3760eda36d/volumes/kubernetes.io~projected/kube-api-access-j6j2v
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/53620555153b8bacd072c90667a8cbc267405ccfcc8f3d8b2c57d7c87e699507/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/2f3310363bff78c0561dca227f3a0b0b3e6b7c32c261ee4a83a48f3fb4589ee0/userdata/shm
tmpfs tmpfs 409600 12 409588 1% /var/lib/kubelet/pods/ab69cf87-fb76-4022-a0a8-4e0056791947/volumes/kubernetes.io~projected/kube-api-access-2hwqf
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/255f1b23-fe6a-4c23-858d-322db6a3831c/volumes/kubernetes.io~projected/kube-api-access-fhn8m
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/9d57a54bdc5521caa1dcc47cd0a303fd05988dd6882a3f923a651008ed6d85e3/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/fcc6b23a4b542f932eef8208af3fe0089f8c1a0aaaf48ad4dcd6f34dfa09ba76/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/b5e089529d180d5951ad39b17afd099e4dd043b7d3e088a53167f4027a6685b2/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/0f9a6eb13e3c3b0a093d744b26120a1cd142ab3d3b8619146c3c4b5e4eb11f29/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/4f23901b445d60f3839b3f23cee21d16f376b5e31f8d9d753ccf49a5e763fa81/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/ec444493c144cc9288622c8f8856f532c7fdda3e98a9fbaab1b2120ecd1f8659/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/794cd5d09a1d8b2082040946220d6fcad02379165b873a829d06116aa30d1726/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/b4c49343419b8257c7b3d1a7d918bf9323eb20db8c9643adfecbee2648481400/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/6bd51793edfe2d4277d05e4b907c82663d61abbc3bed0b9558dc0f8eaad511f9/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/419046bcbe0b74fa0f64cd6e848fe27a4230acc750981fabcce7a2e359c64ef6/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/789089861c6646814bc39063c660d6417d81a623bd2288e0b17eb94dfcf459d2/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/3a2318a1ad3fb59edb02b972e40635662ad01dd31d6ef646659cb2d1e85c62b2/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/45b5697f981024f25fa9e67772a6f61dbd107868007173dffe4598e9dca17d7c/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/af0269c58383a1675f2c1e15e425a0c64dcf6d71e1899e307e62298e842495a2/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/0faadc7f5e95b492a909f19cd620d0c95d9467e576cc8e439cbb620dd67fef89/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/f05177892acb9f6fd33f25973ae9491d4d71fafd8023b8cb44d3b46d986e4c26/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/4d70d2707384e5100eff545a724570ef06ebcb00fb7f5208716c8d181c09ab6b/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/762c79b06a80411408215f349322694bf8c974ca7377eb6512ce70822c5474d6/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/a1d71896dfc46cca5ad82d1c75f7e1123d2f328ae9237541fd8b06d4f7b8dd5b/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/c4e24d9e5d8404818e64a8ce5487306059ad9e83d1cdc569b31c67fe98186b3e/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/8beb09966e0fb611ace5185516a862340267263e33bbfb9952c0960914ded0a5/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/f3ce80ebac20efdf0a304d5510fe03ad40e35b0d325a104c7d831692106c5fe9/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/475cf99b86e421650b41f9446d212552399f3031de6ab1f722377a68e27ee146/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/c75cee6593228269c17c9d4ffe3a839fd5a39713a6bb89b14a05f3856a8e0caa/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/f58d5876ced53f36e35cdc0eb2ae63ebe9d6309526a655094ae101fdbfa44ee2/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/7efc281cee46c626abf0568bacdb192cd678bb21245d6785450fbdefb2ff0d9f/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/8303484194b3a9db60aee9f05b483be7fcd84a9b73a44eafff1b29c915208161/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/2ae3a005e8ffb1432e476d74be88f572c62fa4bc41ba27f9152fb8683f970637/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/082f273299c328f600b977465b261c1535bb8878485226887aeee3de2e79ef20/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/b925d2135b65522cc70f24e9ea395745193efd47e51f5b08aab9fad660fe048d/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/d90a5a170fcd13c1048290a6b38776e777edac80ae5b9bd1f0ac3969c2c2c9ef/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/14eca4540aff532568b47fa8ad76a36138740a8a73967ec95d70428d092e977e/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/4003166e7102b4c231eb2db57a7e6e82a47de862e456a3f79cce5a7fccb5d35f/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/8907c19d6147a41d8d54f53392f24f6ca1519c9c06a2c32dd2879fd5c8198175/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/f1b773bf1899a2e2ff905f590e0162e171ac608ad197be7d10a94551ed36ff79/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/908e0eb0a8dbf3dc50a98d527f6384b0c7f74819a0c1562672e7dcdfabe4822a/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/515133e487ea254c9ca1b8809f7a7429d7ac6e8558c5539a5d3d5dbaf1d51a23/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/2f7fd02f7711df1e9e4c5cd7c686c39378ca78dc718cb6911cda573abe5e049c/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/1466e81b6e70c5c69888fa73d260a8dbc409bf4818f810e5b2632fc77b11574d/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/dc3651da8147c232f3bdada687570718fd5b302a3865641bb296ddb7746c1c95/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/43aadc3f87cf8d815417b47c3bedbc128b30c1e499427e7e5ead9a4f752dc197/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/7d48d8b57cd5e33d88ff924d0dc16c95253ba4212dfe8f7d625372a2b38a9998/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/3b5e55994a9c1a55e2e9850e3f541ec05f6e231543d9b349b31eb8aa2b442e98/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/92c64ce08e953e456c594a320fbd567229937819f977a167a9dd25d5b10b6ee1/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/d9550f31d5512f86322f715d890250832f5a7b39e468586715eb9d0bbbcc6922/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/1a4e7392d932894650cb3ff31146c2de2301f623c8833c6af6c99d89bcf18469/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/2c56dd599050f675039c6d425d6439025cf3b29bb8276d880cd2340c0cec84b7/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/990a32a254340613c8d636d23d6521df5175b1da586f0db19e35e1541f1ccbfe/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/059b3f87ff3072cf872bdcaa643a1d38d630fc0f9c2a78f282e3a176fc16bc97/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/768698dfa7645fee1d9cf830913b94c0d07b15cbd6e3cf8717f2155b2cea51f6/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/27b1fa874408071b090be4ee945cd5b416a0f91ecd7c69b476e2b7fd5698d652/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/4356800d8881dbe0f37bafeddf4abfe9b84b1b618b128fcebc1aeff1f458c15e/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/c025c275db4baf0d081ee4675e1888aaca629ed55f1212714229ccf9a8dbe5a4/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/b1533c2427ffdf16bf62d6d5ed0df7aba2f4ea3fefa963392cef69bc97856ce9/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/f4e204fe957a7c57bdf4bd77c31c745e7a516ad5239e656c9ef70a5298339958/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/15db1e6ecdc9524feb26999d96890874a2bfe2ace9c26db438f2707bdf3ae88e/merged
tmpfs tmpfs 8028992 8 8028984 1% /var/lib/kubelet/pods/ed5aeb0d-8d0b-4be2-a1f2-4ba7678c0472/volumes/kubernetes.io~projected/config
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/ed5aeb0d-8d0b-4be2-a1f2-4ba7678c0472/volumes/kubernetes.io~projected/serviceaccount
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/cd32ce7eafd40fb04bbc52a59a95c4b20b93f2ab207ef69304f48a250e4f0795/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/933763d3768ec739ec41f5d13dacc8aec5b75acfdfd84b280f78c6ebb7075134/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/249fe218532b1cc12c78ceeddac49b3495bc0e54cd23e5a20792dacbea7af535/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/aa0cc0b648128cb2a3b3bd9a27e31c11931f7d531b00f12cf25c31241809abbf/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/80cffe3b2c33faa40e23329d9386b171393551f5e3cdea1d84b178d7af24f11d/merged
tmpfs tmpfs 786432 8 786424 1% /var/lib/kubelet/pods/8e70388f-183b-4b6a-9f3c-f22481891468/volumes/kubernetes.io~projected/kafka-sasl
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/809beac673a7b9c378403f33d1571e62bfa88276ecfaf3e695e98348bdc092a6/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/be71147daf0353c684ec1b987482c9a5e5084407f586dc7525d902e505da4178/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/c3cd9f6ecf0f0fe03f3f179e32fa4f2ac0621556d14d56392dd338f266a24521/merged
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/0c687b36-3570-4259-ad3a-187205fc7302/volumes/kubernetes.io~projected/kube-api-access-6qf6q
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/2bd2b17d-20c7-4999-acb2-8c668d6a547f/volumes/kubernetes.io~projected/kube-api-access-plnrg
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/3924ed8e-4d33-4b24-809c-08844b412116/volumes/kubernetes.io~projected/kube-api-access-dtjfc
tmpfs tmpfs 8028992 12 8028980 1% /var/lib/kubelet/pods/9ec779b8-74ef-4bdb-b4e0-034fb5656681/volumes/kubernetes.io~projected/kube-api-access-jpghs
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/f56413140816f63e5db0af0c46f78bf9bca94222e56c8e2febc6de6091e4763c/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/88d2db09c78b16244bca6d227a471c82faec4da9341be925d707f7f6ff948161/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/09069db094c6b60f94b70a1585a41fd76ac0317a70d179f145597bb9ee9d12c4/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/1531693adc7daecf4b42a9f65d79797900c536e9a2a6b84b072ff5d4c281e112/merged
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/1645c651751721d54f2d0ab70f8fe32bfddc416d1945e5861a1cd1c385634803/userdata/shm
shm tmpfs 65536 0 65536 0% /run/containers/storage/overlay-containers/8456271722ec7e9097a4955a48cc8baac3c4439427c3c224f18256bf4d8af707/userdata/shm
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/8f0e96a0b09274f360015cf2a6d558aa69c50b05e17a83d79c54b7e2bfed584a/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/9291dafa8f9e95d0be86bac293dfc87c006a14756c9cc4d6663a71cb2d930a62/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/cc9a90cd44719e5c8f2996e6547958d16fe7be3351873c61882ae35c158de030/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/4449663b677af05ba16f6ff80919fa330266d9270a8052b5ee6d10d5ab9f937e/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/72ed7746ce479632b2410de59bac64de203769d1054e37a7a41fdddd0c491bce/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/c23eccf9ef98ff3714a8ea7a3405f872b0ca819fd970e2f46f21bc689aa553fc/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/67cf28f187bb37da6a6daa1bdb45dc0d81d08fe74d233c75b250d9055a9e2e1a/merged
overlay overlay 151337312 24762932 119890104 18% /var/lib/containers/storage/overlay/49f0e175313e816ffd9530d906effe3b82c4296b403148848c2e6b2346bab0ea/merged
<<<df_v2>>>
[df_inodes_start]
tmpfs tmpfs 1016424 1885 1014539 1% /run
efivarfs efivarfs 0 0 0 - /sys/firmware/efi/efivars
/dev/mapper/ubuntu–vg-ubuntu–lv ext4 9633792 375072 9258720 4% /
tmpfs tmpfs 1016424 1 1016423 1% /dev/shm
tmpfs tmpfs 1016424 3 1016421 1% /run/lock
/dev/sdb2 ext4 131072 313 130759 1% /boot
/dev/sdb1 vfat 0 0 0 - /boot/efi
tmpfs tmpfs 1016424 3 1016421 1% /var/lib/kubelet/pods/5d07b854-99fe-41a9-b099-b1bd7c0ac93d/volumes/kubernetes.io~empty-dir/dshm
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/9cbcb159-7012-4688-b4e7-713b435c1d1a/volumes/kubernetes.io~projected/kube-api-access-bt5bt
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/f908c391-082e-45bd-8a63-b733cc331586/volumes/kubernetes.io~projected/kube-api-access-8clxl
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/938d752d-12d9-4a25-9b99-352e3e34c009/volumes/kubernetes.io~projected/kube-api-access-6gb5j
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/c9e3dd75-ecb3-4ff2-acc2-f7a73ea1967b/volumes/kubernetes.io~projected/kube-api-access-zd7r4
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/f62975d9-119e-480f-8fbd-b9b482b6cf7a/volumes/kubernetes.io~projected/kube-api-access-mvhrh
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/b2df587a-0375-49ab-a153-ebe4e2541aab/volumes/kubernetes.io~projected/kube-api-access-255qd
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/47cecfa6-d753-44e8-9016-2314b7bdbd03/volumes/kubernetes.io~projected/kube-api-access-p27jm
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/c76796c7-855e-46e4-a3bc-7b063052001d/volumes/kubernetes.io~projected/kube-api-access-n99sm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/1e7369d59187ba86d6b775a4c60dd526e739e43a004f4a877ae39235e5f04ba5/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/3787dd3a98f49756987a24cae35a15c0bb0aa77385465fc9c19df8f32921209d/merged
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/5d07b854-99fe-41a9-b099-b1bd7c0ac93d/volumes/kubernetes.io~projected/kube-api-access-blmxh
tmpfs tmpfs 1016424 5 1016419 1% /var/lib/kubelet/pods/29b829f1-60f1-448d-9db3-f1d74411569d/volumes/kubernetes.io~secret/memberlist
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/29b829f1-60f1-448d-9db3-f1d74411569d/volumes/kubernetes.io~projected/kube-api-access-lftjm
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/7409c6f7-07be-463a-a34d-ed11f4dc18a1/volumes/kubernetes.io~projected/kube-api-access-r8bxw
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/0a1c257a-d21b-41e0-b5db-9d3760eda36d/volumes/kubernetes.io~projected/kube-api-access-j6j2v
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/53620555153b8bacd072c90667a8cbc267405ccfcc8f3d8b2c57d7c87e699507/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/2f3310363bff78c0561dca227f3a0b0b3e6b7c32c261ee4a83a48f3fb4589ee0/userdata/shm
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/ab69cf87-fb76-4022-a0a8-4e0056791947/volumes/kubernetes.io~projected/kube-api-access-2hwqf
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/255f1b23-fe6a-4c23-858d-322db6a3831c/volumes/kubernetes.io~projected/kube-api-access-fhn8m
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/9d57a54bdc5521caa1dcc47cd0a303fd05988dd6882a3f923a651008ed6d85e3/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/fcc6b23a4b542f932eef8208af3fe0089f8c1a0aaaf48ad4dcd6f34dfa09ba76/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/b5e089529d180d5951ad39b17afd099e4dd043b7d3e088a53167f4027a6685b2/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/0f9a6eb13e3c3b0a093d744b26120a1cd142ab3d3b8619146c3c4b5e4eb11f29/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/4f23901b445d60f3839b3f23cee21d16f376b5e31f8d9d753ccf49a5e763fa81/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/ec444493c144cc9288622c8f8856f532c7fdda3e98a9fbaab1b2120ecd1f8659/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/794cd5d09a1d8b2082040946220d6fcad02379165b873a829d06116aa30d1726/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/b4c49343419b8257c7b3d1a7d918bf9323eb20db8c9643adfecbee2648481400/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/6bd51793edfe2d4277d05e4b907c82663d61abbc3bed0b9558dc0f8eaad511f9/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/419046bcbe0b74fa0f64cd6e848fe27a4230acc750981fabcce7a2e359c64ef6/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/789089861c6646814bc39063c660d6417d81a623bd2288e0b17eb94dfcf459d2/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/3a2318a1ad3fb59edb02b972e40635662ad01dd31d6ef646659cb2d1e85c62b2/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/45b5697f981024f25fa9e67772a6f61dbd107868007173dffe4598e9dca17d7c/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/af0269c58383a1675f2c1e15e425a0c64dcf6d71e1899e307e62298e842495a2/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/0faadc7f5e95b492a909f19cd620d0c95d9467e576cc8e439cbb620dd67fef89/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/f05177892acb9f6fd33f25973ae9491d4d71fafd8023b8cb44d3b46d986e4c26/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/4d70d2707384e5100eff545a724570ef06ebcb00fb7f5208716c8d181c09ab6b/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/762c79b06a80411408215f349322694bf8c974ca7377eb6512ce70822c5474d6/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/a1d71896dfc46cca5ad82d1c75f7e1123d2f328ae9237541fd8b06d4f7b8dd5b/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/c4e24d9e5d8404818e64a8ce5487306059ad9e83d1cdc569b31c67fe98186b3e/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/8beb09966e0fb611ace5185516a862340267263e33bbfb9952c0960914ded0a5/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/f3ce80ebac20efdf0a304d5510fe03ad40e35b0d325a104c7d831692106c5fe9/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/475cf99b86e421650b41f9446d212552399f3031de6ab1f722377a68e27ee146/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/c75cee6593228269c17c9d4ffe3a839fd5a39713a6bb89b14a05f3856a8e0caa/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/f58d5876ced53f36e35cdc0eb2ae63ebe9d6309526a655094ae101fdbfa44ee2/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/7efc281cee46c626abf0568bacdb192cd678bb21245d6785450fbdefb2ff0d9f/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/8303484194b3a9db60aee9f05b483be7fcd84a9b73a44eafff1b29c915208161/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/2ae3a005e8ffb1432e476d74be88f572c62fa4bc41ba27f9152fb8683f970637/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/082f273299c328f600b977465b261c1535bb8878485226887aeee3de2e79ef20/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/b925d2135b65522cc70f24e9ea395745193efd47e51f5b08aab9fad660fe048d/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/d90a5a170fcd13c1048290a6b38776e777edac80ae5b9bd1f0ac3969c2c2c9ef/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/14eca4540aff532568b47fa8ad76a36138740a8a73967ec95d70428d092e977e/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/4003166e7102b4c231eb2db57a7e6e82a47de862e456a3f79cce5a7fccb5d35f/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/8907c19d6147a41d8d54f53392f24f6ca1519c9c06a2c32dd2879fd5c8198175/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/f1b773bf1899a2e2ff905f590e0162e171ac608ad197be7d10a94551ed36ff79/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/908e0eb0a8dbf3dc50a98d527f6384b0c7f74819a0c1562672e7dcdfabe4822a/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/515133e487ea254c9ca1b8809f7a7429d7ac6e8558c5539a5d3d5dbaf1d51a23/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/2f7fd02f7711df1e9e4c5cd7c686c39378ca78dc718cb6911cda573abe5e049c/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/1466e81b6e70c5c69888fa73d260a8dbc409bf4818f810e5b2632fc77b11574d/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/dc3651da8147c232f3bdada687570718fd5b302a3865641bb296ddb7746c1c95/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/43aadc3f87cf8d815417b47c3bedbc128b30c1e499427e7e5ead9a4f752dc197/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/7d48d8b57cd5e33d88ff924d0dc16c95253ba4212dfe8f7d625372a2b38a9998/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/3b5e55994a9c1a55e2e9850e3f541ec05f6e231543d9b349b31eb8aa2b442e98/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/92c64ce08e953e456c594a320fbd567229937819f977a167a9dd25d5b10b6ee1/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/d9550f31d5512f86322f715d890250832f5a7b39e468586715eb9d0bbbcc6922/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/1a4e7392d932894650cb3ff31146c2de2301f623c8833c6af6c99d89bcf18469/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/2c56dd599050f675039c6d425d6439025cf3b29bb8276d880cd2340c0cec84b7/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/990a32a254340613c8d636d23d6521df5175b1da586f0db19e35e1541f1ccbfe/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/059b3f87ff3072cf872bdcaa643a1d38d630fc0f9c2a78f282e3a176fc16bc97/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/768698dfa7645fee1d9cf830913b94c0d07b15cbd6e3cf8717f2155b2cea51f6/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/27b1fa874408071b090be4ee945cd5b416a0f91ecd7c69b476e2b7fd5698d652/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/4356800d8881dbe0f37bafeddf4abfe9b84b1b618b128fcebc1aeff1f458c15e/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/c025c275db4baf0d081ee4675e1888aaca629ed55f1212714229ccf9a8dbe5a4/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/b1533c2427ffdf16bf62d6d5ed0df7aba2f4ea3fefa963392cef69bc97856ce9/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/f4e204fe957a7c57bdf4bd77c31c745e7a516ad5239e656c9ef70a5298339958/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/15db1e6ecdc9524feb26999d96890874a2bfe2ace9c26db438f2707bdf3ae88e/merged
tmpfs tmpfs 1016424 7 1016417 1% /var/lib/kubelet/pods/ed5aeb0d-8d0b-4be2-a1f2-4ba7678c0472/volumes/kubernetes.io~projected/config
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/ed5aeb0d-8d0b-4be2-a1f2-4ba7678c0472/volumes/kubernetes.io~projected/serviceaccount
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/cd32ce7eafd40fb04bbc52a59a95c4b20b93f2ab207ef69304f48a250e4f0795/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/933763d3768ec739ec41f5d13dacc8aec5b75acfdfd84b280f78c6ebb7075134/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/249fe218532b1cc12c78ceeddac49b3495bc0e54cd23e5a20792dacbea7af535/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/aa0cc0b648128cb2a3b3bd9a27e31c11931f7d531b00f12cf25c31241809abbf/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/80cffe3b2c33faa40e23329d9386b171393551f5e3cdea1d84b178d7af24f11d/merged
tmpfs tmpfs 1016424 7 1016417 1% /var/lib/kubelet/pods/8e70388f-183b-4b6a-9f3c-f22481891468/volumes/kubernetes.io~projected/kafka-sasl
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/809beac673a7b9c378403f33d1571e62bfa88276ecfaf3e695e98348bdc092a6/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/be71147daf0353c684ec1b987482c9a5e5084407f586dc7525d902e505da4178/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/c3cd9f6ecf0f0fe03f3f179e32fa4f2ac0621556d14d56392dd338f266a24521/merged
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/0c687b36-3570-4259-ad3a-187205fc7302/volumes/kubernetes.io~projected/kube-api-access-6qf6q
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/2bd2b17d-20c7-4999-acb2-8c668d6a547f/volumes/kubernetes.io~projected/kube-api-access-plnrg
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/3924ed8e-4d33-4b24-809c-08844b412116/volumes/kubernetes.io~projected/kube-api-access-dtjfc
tmpfs tmpfs 1016424 9 1016415 1% /var/lib/kubelet/pods/9ec779b8-74ef-4bdb-b4e0-034fb5656681/volumes/kubernetes.io~projected/kube-api-access-jpghs
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/f56413140816f63e5db0af0c46f78bf9bca94222e56c8e2febc6de6091e4763c/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/88d2db09c78b16244bca6d227a471c82faec4da9341be925d707f7f6ff948161/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/09069db094c6b60f94b70a1585a41fd76ac0317a70d179f145597bb9ee9d12c4/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/1531693adc7daecf4b42a9f65d79797900c536e9a2a6b84b072ff5d4c281e112/merged
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/1645c651751721d54f2d0ab70f8fe32bfddc416d1945e5861a1cd1c385634803/userdata/shm
shm tmpfs 1016424 1 1016423 1% /run/containers/storage/overlay-containers/8456271722ec7e9097a4955a48cc8baac3c4439427c3c224f18256bf4d8af707/userdata/shm
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/8f0e96a0b09274f360015cf2a6d558aa69c50b05e17a83d79c54b7e2bfed584a/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/9291dafa8f9e95d0be86bac293dfc87c006a14756c9cc4d6663a71cb2d930a62/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/cc9a90cd44719e5c8f2996e6547958d16fe7be3351873c61882ae35c158de030/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/4449663b677af05ba16f6ff80919fa330266d9270a8052b5ee6d10d5ab9f937e/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/72ed7746ce479632b2410de59bac64de203769d1054e37a7a41fdddd0c491bce/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/c23eccf9ef98ff3714a8ea7a3405f872b0ca819fd970e2f46f21bc689aa553fc/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/67cf28f187bb37da6a6daa1bdb45dc0d81d08fe74d233c75b250d9055a9e2e1a/merged
overlay overlay 9633792 375072 9258720 4% /var/lib/containers/storage/overlay/49f0e175313e816ffd9530d906effe3b82c4296b403148848c2e6b2346bab0ea/merged
mike1098
(Michael FRANK)
September 15, 2025, 8:46am
5
Sorry but I believe that I misunderstood your real issue. May you explain a little more in detail?
In your screenshot you show that the services are disabled, so they should not appear anymore in monitoring.
As I tried to explain the discovery process runs earlier and as far as I can see there is no way to exclude FS base on the mountpoint.
I am currently discussing the issue that we have an increasing number of disabled services in that case.
regards
Mike
Steven1
(Steven)
September 15, 2025, 8:55am
6
The increasing amount of disabled services might become a problem in the future, but isn’t one right now.
My issue is that when a discovery run, and new overlay systems are detected, it will display it as a warning, as is intended.
But I would like to NOT display this and move straight to disabled services. This doesn’t happen for now. It is a manual process to move to disabled services.
mike1098
(Michael FRANK)
September 15, 2025, 9:40am
7
May you describe the manual process pls.
Thanks
Mike
Steven1
(Steven)
September 15, 2025, 11:24am
8
Sure, I’ll try to make it clear:
1: A new overlay is detected:
2: I click “Run Service discovery”
3: I select the newly found undecided service(s)
4: I select action and choose “disable undecided services”
I hope that clears up how the process works untill now
mike1098
(Michael FRANK)
September 16, 2025, 12:42pm
9
Please post agent output as code in the future. That way I can just copy paste it
mike1098
(Michael FRANK)
September 16, 2025, 12:48pm
10
If you choose that way you create for each FS a dedicated rule.
Basically you should able to cover that with one rule as you already showed here:
For example:
Created the rule ‘Disabled services’ with Filesystem /usr/sap/.* in services field, activate the changes and a rediscover shows this:
The boot FS is disabled by another rule.
