I just had an issue on a site where we are using Kubernetes Monitoring
as per Monitoring Kubernetes.
I have to use version 2.0 for now, because the clusters I’m monitoring
with Checkmk are on OpenShift 3.x, and I don’t know if the “newer”
implementation starting with 2.1, works for OpenShift 3.x.
So it looks like, Checkmk did not exclude “Evicted” pods in its calculation.
Again: The instance in question is a “RAW” edition in version 2.0.0p34. I’m
aware of the fact that there is a newer release in the “2.0” branch, so
I haven’t checked werks, but if there aren’t any, I believe this is a bug.
“Very old” ? There was a release in the 2.0 branch yesterday, Aug 10th 2023: Checkmk 2.0.0p38
Anyway… Does Checkmk 2.1 or 2.2 support OpenShift 3.x in the RAW edition?
If yes then I’m happy to embark on this adventure. If not, I cannot do this, and simply “lose monitoring”.
Furthermore the - quite specific potential bug - I’m pointing out was more FYI, in case it affects
other versions, too…
You are right, 2.0.0 still receives security updates and some bug fixes until the beginning of September. Then the passive support ends, putting the version into EOL.
What I mean with “very old”: There were two major releases with tons of features and improvements after 2.0.0. Updating is inevitable. Or as the Borg say: “Resistance is futile”.
Partial monitoring of openshift clusters is possible in 2.1 and 2.2
Full monitoring in 2.2 with the cloud edition
In 2.1, via the right scc and selinux changes, full monitoring is possible but not recommended.
There is enough material in the docs explaining this, please check it out. We also shared updates on recent Checkmk conferences on this topic
