I managed to set up the LDAP authentication using IPA yesterday and I am able to log in with the LDAP users.
However, I am not able to make the role synchronization do what it should…
I have one group of LDAP users that I want to give access to checkmk and also make them admins.
So I have Group base DN and Roles->Administrator-> Group DN set to exactly the same value.
Upon save and test it also reports Sync-Plugin: Roles Success Found all 1 groups.
Still, all synchronized users end up as “Normal monitoring user”…
Any idea on how to debug this?
Things I tried:
set group base DN to the level above the group and change to “check groups one level below”, the user filter is set to (&(objectclass=posixAccount)(memberOf=<The Admin DN>))
define member attribute
define group search filter
another group that the tested user is in (in the one level below case, it was also found)
CMK version: Checkmk Raw Edition 2.2.0p21 Docker OS version: Ubuntu 22.04
Yeah, that’s what I did initially (also see things I tried).
The results then is:
Connection Success Connection established. The connection settings seem to be ok.
User Base-DN Success The User Base DN could be found.
Count Users Success Found 4 users for synchronization.
Group Base-DN Success The Group Base DN could be found.
Count Groups Success Found 250 groups for synchronization.
However, it does not lead to the user being seen as Administrator.
Thanks, so this tells me that upon synchronization it searches the following: LDAP_SEARCH "cn=<Admin group>,<group_base_dn>" "base" "(objectclass=posixgroup)" "['cn', 'memberof']"
I had this mixed up, it should not look for memberof but instead it obviously should look for the members → the member attribute.
