Hi - I have a group of users that gets imported via LDAP. As part of the LDAP config I have used the custom attribute option to set a specific start URL to display:
But when a user logs in they just get the default dashboard.
When I view the user settings the Start URL option is blank and not configurable:
I have tested the start URL with a non LDAP user and it works perfectly.
It is working for the setting âRolesâ where I set them to be a normal monitoring user using the same group. But for the custom user attributes it just doesnt work.
For the Roles, the field is asking for a Group DN - something like âCN=Group Name I Want,OU=Group Container,DC=corp,DC=test,DC=localâ
For the Groups to custom user attribute it is asking for a Group CN - so for that DN, the CN would be âGroup Name I Wantâ. Donât even include the leading CN - only the actual group name.
I see in your screenshot you have a Group DN in that field, not a CN. Changing it to a CN should fix it.
Additionally, after you save & test, the changes donât happen until the next scheduled LDAP sync interval (default is 5 minutes), so wait after you apply your changes to see if theyâre working.
