I am searching for a list of perfdata keys that are working out-of-the-box without having to create a separate perfometer file on the site.
The keys I found out so far:
I couldn’t find any official documentation, but maybe someone has this lying around on their computer?
Dirk
September 13, 2020, 2:51pm
2
Actually a Perf-O-Meter is only drawn for load1
, not for load5
or load15
Depending on your checkmk version the interesting file is ~/lib/python/cmk/gui/plugins/metrics/check_mk.py
. Before 1.6 it was located below ~/share/check_mk/web/plugins/metrics
and called differently, IIRC.
Here’s an excerpt of the file:
perfometer_info.append({
"type": "logarithmic",
"metric": "load1",
"half_value": 4.0,
"exponent": 2.0
"type": "dual",
"perfometers": [
"metric": "if_in_bps",
"half_value": 5000000,
"exponent": 5,
"metric": "if_out_bps",
"exponent": 5,
That is: if you return performance data named load1
or (if_in_bps
and if_out_bps
), a Perf-O-Meter will be drawn.
I don’t have a list but a fancy combination of sed
and grep
or awk
should reveal all metric
s inside those perfometer_info.append(…)
sections.
It is not only the “metric” entries. Also you should pay attention to the “segments”.
Like this example.
"type": "linear",
"segments": ["shared_locks", "exclusive_locks"],
"total": None,
For all unique entries in “metric” and “segments”, where perfdata values exists, a perf-o-meter will be drawn.
system
(system)
Closed
September 13, 2021, 2:57pm
4
