"live_example.py" for Using LQL in Python get stucked
CMK version: Checkmk Enterprise Edition 2.1.0p6
OS version: Red Hat Enterprise Linux 8.6 (Ootpa)
**Error message: The “live_example.py” for Using LQL in Python that Check_mk uploaded in the check_mk docs get stucked in the ‘while’ loop and never ends.
This is where the code get stucked:
# receive the reply as a JSON string
chunks = []
while len(chunks) == 0 or chunks[-1] != "":
    chunks.append(sock.recv(4096))
sock.close()
reply = "".join(chunks)
Please, Any help about what is going wrong? Could someone share a running example?
BR.
I guess you mean this sample script in the official Checkmk User Guide. I played a bit with it myself and I think there are some issues:
the sock.sendall expects byte encoded data not a string
sock.sendall("GET status\nOutputFormat: json\n")
so this should be changed to
sock.sendall("GET status\nOutputFormat: json\n".encode())
than you ned the decode the recived data from bytes into str. Change
to
chunks.append(sock.recv(4096).decode())
the last issue I run into is the default blocking state of the socket (see [ python: loop with socket.recv()](python: loop with socket.recv() - Stack Overflow)
After I changed the socket type from blocking to non blocking (sock.setblocking(False)) and added a sleep timer (sleep(5)). I was finaly able to get the script working.
sock = socket.socket(family, socket.SOCK_STREAM)
sock.connect(address)
sock.sendall(str.encode("GET status\nOutputFormat: json\n"))
sock.shutdown(socket.SHUT_WR)
sleep(5)
The issue with this might be the sleep timer, as it depends on how long your querry takes to complete.
@mschlenker Can you take a look at the sample LQL script in the documentation? It may need some polishing :wink:
Thanks. Bookmarked the thread for my collection for late Q3 when “11. Automation and development” is on the agenda. (Still might have a look earlier)
Thank you so much for your attention.
I added your suggestions but still failing. Sorry, I have poor knowledge about sockets.
Here is the error:
socket.error: [Errno 11] Resource temporarily unavailable
…and here is the code:
#!/usr/bin/env python
# Sample program for accessing Livestatus from Python
import json, os, socket
import time
# for local site only: file path to socket
address = "%s/tmp/run/live" % os.getenv("OMD_ROOT")
# for local/remote sites: TCP address/port for Livestatus socket
# address = ("localhost", 6557)
# connect to Livestatus
family = socket.AF_INET if type(address) == tuple else socket.AF_UNIX
time.sleep(5)
# send our request. sock.sendall expects byte encoded data
# you ned the decode the recived data from bytes into str, and convert as a JSON
chunks = []
sock.close()
# print the parsed reply
print(json.loads(reply))
Forums say that is because of the “non-blocking” state.
Anyway, This is so frustrating and complicated. I tried differenta approach using “lq” and os.popen() and it worked
   command = "lq \"GET comments\nColumns: service_comments_with_info\nFilter: host_name = %s\nFilter: service_description = %s\" | awk 'NR==1'" % \
                (hostname, servicedesc)
            output = os.popen(command).read()  # nosec
BR.
you need to move the time.sleep(5) behind the sock.shutdown(socket.SHUT_WR). And I asume you try this directly as siteuser on the CMK server.
Here my variant of the script:
import json
import os
import socket
from time import sleep
from pprint import pp
def get_lq_data(querry: str):
    sock.sendall(querry.encode())
    sleep(1)
    chunks = []
    sock.close()
    print(f'# of chunks: {len(chunks)}')
    if len(chunks):
        reply = json.loads("".join(chunks))
        return reply
    else:
        return {}
pp(get_lq_data("GET hosts\nColumns: name address\nOutputFormat: json\nFilter: host_name ~ ro01.*\nColumnHeaders: on\n"))
returns:
[['name', 'address'], ['ro01-auth', '192.168.10.124'], ['ro01wlc', '192.168.10.142'], ['ro01', '192.168.10.124'], ['ro01-noauth', '192.168.10.124']]
It worked!!
Thank you so much for the help.
BR.
This slipped through the cracks. Sorry about that.
The example is now fixed in the user guide as well. Please do check out the fixed example in the user guide, because it works without having to use sleep(n).
Thanks to @thl-cmk and @chauhan_sudhir.
Better late than never :wink: THX for updating.
Your example works for me. I have remove the sock.setblocking(False) and sleep(1) from my scrpit. Works now without them to. No idea why it was needed before.
