Error message:[Errno 104] Connection reset by peer
**Hello, i newly created new docker installation of CheckMK raw. On my primary site I added this new site (connection) into Distributed monitoring, but Livestatus end with “[Errno 104] Connection reset by peer”. Login was successfull, I see the status Online.
I am really confused, becaused I use the same configuration as in my another Docker remote site installation without any problem. All installations have the same version.
I also check Firewall and there is visible communication between primary site and remote site.
This is the funny fact. CMK_LIVESTATUS_TCP is already set to “on”. Port 6557/tcp exposed and verified on Firewall that primary site is successfully communicating with the site. Configuration connection on port 5010/tcp is working properly. Only the 6557/tcp is not working properly.
So I tried to change the port 6557/tcp to 5009/tcp and it ends with the same error.
Simon, thank you so much for your time and effort. I figured out.
The problem was that I put CMK_LIVESTATUS_TCP as Docker variable, but I had to go into Docker container terminal and set proper values also in omd config.
