I just downloaded the LLDP cache plugin but it’s not working. I can edit the ruleset “LLDP cache” but nothing shows up in inventory. (Yes, I refreshed the inventory and I’m trying to read HPE switches)
Does someone else use this plugin? Does it work for you?
You need to remove line 46 “@dataclass” from the file ~/local/lib/check_mk/base/plugins/agent_based/inv_lldp_cache.py
This is a problem between 2.0 and 2.1 of CMK.
