We did that for our staff internal. Following some powershell code for a singe query:
# SET LOCAL PARAMS
set-executionpolicy RemoteSigned
# SET VARIABLES
# You have TO SET your SQL Server name NEXT :
#if you USE a particular instance, the variable should be "$sqlserver = SERVERNAME\INSTANCE"
#DONT ADD SPACE IN the STRING IF you want TO CHANGE Service_name
$service_name = "MSSQL_CONNECTIONS"
$sqlServer = "localhost" # Example server variable
$database = "master" # Example OF DB Uses
$query = $("SELECT TOP 10 [connections] FROM [master].[dbo].[spt_monitor]") #Query That need TO be replaced
$auth = "BDDUSER" #The other mode IS "IS", IF you want TO USE Windows integrated credentials CHANGE "BDDUSER" BY "IS"
$uid = "User" # Edit TO your specific USER
$pwd = "Password" #Edit TO your specific
# NO TOUCHING
#Connection Method Test
IF ($auth -eq "BDDUSER") {
$connString = "Server=$sqlServer;Database=$database;User Id=$uid;Password=$pwd;"
ELSE{
$connString = "Server= $sqlServer;Database=$database;Integrated Security=True;"
#Connect
Try{
$sqlConn = New-Object System.Data.SQLClient.SQLConnection
$sqlConn.ConnectionString = $connString
$sqlCmd = New-Object System.Data.SqlClient.SqlCommand
$sqlCmd.Connection = $sqlConn
$sqlConn.Open()
Catch{
Write-Host "3 $service_name - "$_.Exception.Message
exit
#Query
Try{
#Command One
$sqlCmd.CommandText = $query
$sqlAdapter = New-Object System.Data.SqlClient.SqlDataAdapter
$sqlAdapter.SelectCommand = $sqlCmd
#Fill SQL adapter WITH the dataset AND affect it TO a sqlFill Variable
$dataSet = New-Object System.Data.DataSet
$sqlFill = $sqlAdapter.Fill($dataSet)
$result = $dataSet.Tables[0].Rows.connections
#Liberation OF the LAST Query
$sqlCmd.Dispose()
Catch{
#In any CASE, close the connection
Finally{
$sqlconn.Close()
# EDIT
#We exit ALL TIME WITH this STATUS. here,
#if connections are less than 15 its ok
#Between 15 AND 50 its Warning
#More than 50 its critical
# 0 = OK
# 1 = WARNING
# 2 = CRITICAL
# 3 = UNKNOWN
[INT]$crit_threshold = 50
[INT]$warn_threshold = 2
Try{
#Do anything WITH your RESULT
#In this CASE, We CHECK the total connection NUMBER (that thresholds are just examples)
IF($result -gt $crit_threshold)
{Write-Host "2 $service_name - $result connections (CRIT above "$crit_threshold")"}
elseif($result -gt $warn_threshold)
{Write-Host "1 $service_name - $result connections (WARN between "$warn_threshold" and "$crit_threshold")"}
ELSE
{Write-Host "0 $service_name - $result connections (OK above 0 and below "$warn_threshold")"}
#Maybe ADD SOME FUNCTION TO make Specifics checks AND validate the query
Catch{
#We exit WITH UNKNOWN alert IN CASE something goes wrong WITH thresholding
# DEBUG
#If you want TO know what results you GET FROM your raw SQL query, uncomment the following block
<#Try{
#$dataSet.Tables[0].Rows | Select-Object * -ExcludeProperty ItemArray, TABLE, RowError, RowState, HasErrors | ConvertTo-Json
#$dataSet2.Tables[0].Rows | Select-Object * -ExcludeProperty ItemArray, TABLE, RowError, RowState, HasErrors | ConvertTo-Json
#Catch{
#Write-Host "3 ARRAY Problem(s) : "$_.Exception.Message
#exit
And here some powershell code for multiple queries:
# SET LOCAL PARAMS
# SET VARIABLES
$database = "IJCore" # Example OF DB Uses
$query = $("SELECT TOP 5 [dataCalloffID] FROM [IJCore].[dbo].[archivedCalloff]") #Query That need TO be replaced
$query2 = $("SELECT TOP 2 [dataCalloffAdditionalInteger1] FROM [IJCore].[dbo].[archivedCalloff]") #Query That need TO be replaced
$auth = "IS" #The other mode IS "IS", IF you want TO USE Windows integrated credentials CHANGE "BDDUSER" BY "IS"
# NO TOUCHING
FUNCTION printout_errors($error_code, [string]$message){
#Error Message Printing
$ErrorMessage = $_.Exception.Message
$FailedItem = $_.Exception.ItemName
Write-Host "$error_code $message $ErrorMessage, $FailedItem"
ELSE{
#Connect
Try{
$sqlConn.Open()
Catch{
printout_errors(3,"Connection Problems")
exit
#Query
Try{
#Command One
$sqlCmd.Dispose()
Catch{
printout_errors(2,"MSSQL query failed for the following reason : ")
Try {
#Second Query
$sqlCmd.CommandText = $query2
$dataSet2 = New-Object System.Data.DataSet
$sqlFill2 =$sqlAdapter.Fill($dataSet2)
Catch{
printout_errors(2,"MSSQL query_2 failed for the following reason : ")
Finally{
$sqlconn.Close()
# DEBUG
<#Try{
Catch{
printout_errors(3,"ARRAY Problem(s)")
exit
# EDIT
Try{
#In this CASE, $sqlFill IS a COUNT ON the rownumber you selected ON request
#Example which COUNT ROWS AND define Statement ON this NUMBER
IF($sqlFill -gt 1) {
$result = $dataSet.Tables[0].Rows.Count
Write-Host "0 MSSQL Query OK - $result Rows is OK"
elseif($sqlFill -eq 1){
Write-Host "2 MSSQL Query Warning - $result Rows is Warning"
ELSE{
Write-Host "2 MSSQL Query Critical - $result Rows is Crticial"
Catch{
printout_errors(2,"Custom handling of SQL result failed for the following reason : ")
