CMK version:
Checkmk Enterprise Edition 2.2.0p12
OS version:
Ubuntu 22.04.4 LTS
None
Checkmk version 2.2.0p21
+ FETCHING DATA
Source: SourceInfo(hostname='API-Monitoring', ipaddress='XXX.XXX.XXX.247', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fbc425b20d0]
Read from cache: AgentFileCache(API-Monitoring, path_template=/omd/sites/monitoring_intern/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 8 sec, allowed is 0 sec)
Connecting via TCP to XXX.XXX.XXX.247:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Closing TCP connection to XXX.XXX.XXX.247:6556
Write data to cache file /omd/sites/monitoring_intern/tmp/check_mk/cache/API-Monitoring
Trying to acquire lock on /omd/sites/monitoring_intern/tmp/check_mk/cache/API-Monitoring
Got lock on /omd/sites/monitoring_intern/tmp/check_mk/cache/API-Monitoring
Releasing lock on /omd/sites/monitoring_intern/tmp/check_mk/cache/API-Monitoring
Released lock on /omd/sites/monitoring_intern/tmp/check_mk/cache/API-Monitoring
[cpu_tracking] Stop [7fbc425b20d0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=4.6099999994039536))]
Source: SourceInfo(hostname='API-Monitoring', ipaddress='XXX.XXX.XXX.247', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fbc4353ea10]
Read from cache: NoCache(API-Monitoring, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'API-Monitoring'. Skip processing.
No piggyback files for 'XXX.XXX.XXX.247'. Skip processing.
[cpu_tracking] Stop [7fbc4353ea10 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
+ PARSE FETCHER RESULTS
<<<nfsmounts_v2:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<multipath>>> / Transition HostSectionParser -> HostSectionParser
<<<timesyncd>>> / Transition HostSectionParser -> HostSectionParser
<<<timesyncd_ntpmessage:sep(10)>>> / Transition HostSectionParser -> HostSectionParser
<<<cmk_update_agent_status:cached(1713857796,14400):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
HostKey(hostname='API-Monitoring', source_type=<SourceType.HOST: 1>) -> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cmk_update_agent_status', 'cpu', 'df_v2', 'diskstat', 'job', 'kernel', 'labels', 'lnx_if', 'local', 'md', 'mem', 'mounts', 'multipath', 'nfsmounts_v2', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'timesyncd', 'timesyncd_ntpmessage', 'uptime', 'vbox_guest']
HostKey(hostname='API-Monitoring', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fbc424b8590]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring_intern/tmp/check_mk/counters/API-Monitoring
Got lock on /omd/sites/monitoring_intern/tmp/check_mk/counters/API-Monitoring
Releasing lock on /omd/sites/monitoring_intern/tmp/check_mk/counters/API-Monitoring
Released lock on /omd/sites/monitoring_intern/tmp/check_mk/counters/API-Monitoring
Acronis Cloud Backup - REDACTED, Machine: REDACTED Backup Failed for Customer: REDACTED, Details: BackupFailed, Machine: REDACTED.
CPU load 15 min load: 0.01, 15 min load per core: 0.01 (2 cores)
CPU utilization Total CPU: 21.09%
Check_MK Agent Version: 2.2.0p12, OS: linux, Last update: Apr 19 2024 09:29:34, Agent plugins: 1, Local checks: 3
Disk IO SUMMARY Read: 0.00 B/s, Write: 14.2 kB/s, Latency: 1 millisecond
Filesystem / Used: 40.01% - 7.21 GiB of 18.0 GiB, trend per 1 day 0 hours: +44.0 MiB, trend per 1 day 0 hours: +0.24%, Time left until disk full: 251 days 15 hours
Filesystem /boot Used: 19.05% - 371 MiB of 1.90 GiB, trend per 1 day 0 hours: +16.1 KiB, trend per 1 day 0 hours: +<0.01%, Time left until disk full: 274 years 231 days
Filesystem /boot/efi Used: 0.57% - 6.07 MiB of 1.05 GiB, trend per 1 day 0 hours: +0 B, trend per 1 day 0 hours: +0%
Interface 2 [eth0], (up), MAC: 00:15:5D:79:05:0B, Speed: 1 GBit/s, In: 22.5 kB/s (0.02%), Out: 12.5 kB/s (0.01%)
Kernel Performance Process Creations: 21.85/s, Context Switches: 682.23/s, Major Page Faults: 0.08/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory Total virtual memory: 6.03% - 238 MiB of 3.85 GiB, 9 additional details available
Mount options of / Mount options exactly as expected
Mount options of /boot Mount options exactly as expected
Mount options of /boot/efi Mount options exactly as expected
Number of threads 150, Usage: 1.05%
Systemd Service Summary Total: 147, Disabled: 3, Failed: 0
Systemd Socket Summary Total: 22, Disabled: 0, Failed: 0
Systemd Timesyncd Time Offset: 2 milliseconds, Time since last sync: 28 minutes 39 seconds, Time since last NTPMessage: 28 minutes 39 seconds, Stratum: 2.00, Jitter: 2 milliseconds, Synchronized on 185.125.190.57
TCP Connections Established: 2
Uptime Up since Apr 19 2024 09:22:39, Uptime: 4 days 0 hours
[cpu_tracking] Stop [7fbc424b8590 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[agent] Success, [piggyback] Success (but no data found for this host), execution time 4.6 sec | execution_time=4.630 user_time=0.020 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=4.610
Im currently having the problem that my new local check written in python is being executed by check_mk_agent but is not being discovered by WATO . I’ve already written a local check which creates the above “Acronis Cloud Backup” Services. Running the script from the /usr/lib/check_mk_agent/local/ directory as root seems to be working fine and the output also looks good:
root@srv11snexechost:/usr/lib/check_mk_agent/local# ls -lisa
total 28
934705 4 drwxrwxrwx 3 root root 4096 Apr 23 14:40 .
934704 4 drwxr-xr-x 4 root root 4096 Apr 11 10:23 ..
919010 4 -rwxr-x--x 1 root root 2323 Apr 19 09:27 acronis_failed_backups.py
919004 4 drwxrwxrwx 2 root root 4096 Apr 23 14:40 dfe-configs
938787 4 -rwxr-x--x 1 root root 2359 Apr 19 07:52 encrypt.py
938788 8 -rwxr-x--x 1 root root 4280 Apr 23 14:38 ms365_dfe_incidents.py
root@srv11snexechost:/usr/lib/check_mk_agent/local# ./ms365_dfe_incidents.py
2 "DFE Incident 16 - REDACTED" - Multi-stage incident on one endpoint, Severity: medium
2 "DFE Incident 17 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
2 "DFE Incident 14 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
2 "DFE Incident 10 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
2 "DFE Incident 9 - REDACTED" - Horizontal port scan initiated on one endpoint, Severity: low
2 "DFE Incident 7 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
2 "DFE Incident 6 - REDACTED" - Horizontal port scan initiated on one endpoint, Severity: low
1 "DFE Incident 18 - REDACTED" - Horizontal port scan initiated on one endpoint, Severity: low
1 "DFE Incident 13 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
1 "DFE Incident 11 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
1 "DFE Incident 8 - REDACTED" - Horizontal port scan initiated on one endpoint, Severity: low
1 "DFE Incident 5 - REDACTED" - 'ProductKey' hacktool was prevented on one endpoint, Severity: low
1 "DFE Incident 15 - REDACTED" - Defense evasion incident on one endpoint, Severity: informational
This is the output of running check_mk_agent as root on the host (only the <<< local >>> part):
<<<local:sep(0)>>>
2 "Acronis Cloud Backup - REDACTED, Machine: REDACTED" - Backup Failed for Customer: REDACTED, Details: BackupFailed, Machine: REDACTED.
<<<cmk_update_agent_status:sep(0):cached(1713933675,14400)>>>
{"last_check": 1713933675.3045506, "last_update": 1713876004.014543, "aghash": "c64ee72fa0abd2f0", "pending_hash": null, "update_url": "https://REDACTED/main/check_mk", "trusted_certs": {"0": {"corrupt": false, "not_after": "20250615132624Z", "signature_algorithm": "sha512WithRSAEncryption", "common_name": "main_key"}}, "error": null}
Any Idea what this could be?
If it matters the script is being deployed via the Agent-Bakery and the “Deploy custom file with agent” Rule-Set.
Regards
Kean
