Hello everybody,
I have problems with a local check. As soon as I have a “comma” or a “dot” in the status text of the output, he makes a new line at this dot …
Here is the script, the output of the script and the output from the agent:
Script:
find /backup/RSYNC-BACKUP/. -maxdepth 0 | while read line; do
name=$(echo “$line” | awk -F “^/backup/RSYNC-BACKUP/” ‘{print $2}’)
percent=$(df -h | grep $line | awk ‘{print $5}’ | grep -o ‘[0-9,]+’)
used=$(df -h | grep $line | awk ‘{print $3}’ | grep -o ‘[0-9,]+’)
size=$(df -h | grep $line | awk ‘{print $2}’ | grep -o ‘[0-9,]+’)if [ “$percent” -ge “90” 2>/dev/null ]; then
status=2
statustext=“$percent% used (”$used"GB of “$size"GB)”
elif [ “$percent” -ge “80” 2>/dev/null ]; then
status=1
elif [ “$percent” -lt “80” 2>/dev/null ]; then
status=0
else
status=2
statustext=“Fehler beim auslesen von $line”
fiecho “$status SPACE:$name used=$used $statustext” | sed ‘s/,/./g’
done
Output Script:
0 SPACE:**** used=12 13% used (12GB of 98GB)
0 SPACE:**** used=52 22% used (52GB of 246GB)
0 SPACE:**** used=20 43% used (20GB of 49GB)
0 SPACE:**** used=18 19% used (18GB of 98GB)
0 SPACE:**** used=925 2% used (925GB of 49GB)
0 SPACE:**** used=33 15% used (33GB of 246GB)
2 SPACE:**** used= Fehler beim auslesen von /backup/RSYNC-BACKUP/****
0 SPACE:**** used=30 13% used (30GB of 246GB)
0 SPACE:**** used=562 2% used (562GB of 49GB)
0 SPACE:**** used=6.6 15% used (6.6GB of 49GB)
0 SPACE:**** used=7.0 15% used (7.0GB of 49GB)
0 SPACE:**** used=20 42% used (20GB of 49GB)
0 SPACE:**** used=48 21% used (48GB of 246GB)
0 SPACE:**** used=8.8 10% used (8.8GB of 98GB)
0 SPACE:**** used=54 24% used (54GB of 246GB)
0 SPACE:**** used=39 17% used (39GB of 246GB)
0 SPACE:**** used=151 65% used (151GB of 246GB)
Output from Agent:
cached(1582102357,43200) 0 SPACE:**** used=12 13% used (12GB of 98GB)
cached(1582102357,43200) 0 SPACE:**** used=52 22% used (52GB of 246GB)
cached(1582102357,43200) 0 SPACE:**** used=20 43% used (20GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=18 19% used (18GB of 98GB)
cached(1582102357,43200) 0 SPACE:**** used=925 2% used (925GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=33 15% used (33GB of 246GB)
cached(1582102357,43200) 2 SPACE:**** used= Fehler beim auslesen von /backup/RSYNC-BACKUP/****
cached(1582102357,43200) 0 SPACE:**** used=30 13% used (30GB of 246GB)
cached(1582102357,43200) 0 SPACE:**** used=562 2% used (562GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=6
cached(1582102357,43200) 6 15% used (6
cached(1582102357,43200) 6GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=7
cached(1582102357,43200) 0 15% used (7
cached(1582102357,43200) 0GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=20 42% used (20GB of 49GB)
cached(1582102357,43200) 0 SPACE:**** used=48 21% used (48GB of 246GB)
cached(1582102357,43200) 0 SPACE:**** used=8
cached(1582102357,43200) 8 10% used (8
cached(1582102357,43200) 8GB of 98GB)
cached(1582102357,43200) 0 SPACE:**** used=54 24% used (54GB of 246GB)
cached(1582102357,43200) 0 SPACE:**** used=39 17% used (39GB of 246GB)
cached(1582102357,43200) 0 SPACE:**** used=151 65% used (151GB of 246GB)
Maybe someone has an idea how I could solve this?
Best regards
Niko
