CMK version: 2.1.0p37 for docker
**OS version: Red Hat 8.5.0-16 **
We deployed a custom .ps1 script using the Agent Bakery but there is no <<<local>>> agent section in any of the agentes (we tried windows server 2012 and 2019). We started facing this with check_mk 2.1.0p30 and after upgrading to p37 still the same. One more thing to mention is that sometimes the Agent Bakery process (baske and sign agents) shows an error message in the web console for just couple of seconds, then the message disappear (giving not enough time to read it) and the bake process finish successfully
Checkmk version 2.1.0p37
Trying to acquire lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Got lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Got lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Released lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Released lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f27a6bc6220]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(<hostname>, base_path=/omd/sites/cmk/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=90, inventory=90), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 20 sec, allowed is 0 sec)
Connecting via TCP to 10.10.10.10:6556 (5.0s timeout)
Reading data from agent
Write data to cache file /omd/sites/cmk/tmp/check_mk/cache/<hostname>
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/cache/<hostname>
Got lock on /omd/sites/cmk/tmp/check_mk/cache/<hostname>
Releasing lock on /omd/sites/cmk/tmp/check_mk/cache/<hostname>
Released lock on /omd/sites/cmk/tmp/check_mk/cache/<hostname>
Closing TCP connection to 10.10.10.10:6556
[cpu_tracking] Stop [7f27a6bc6220 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=20.87999999988824))]
[cpu_tracking] Start [7f27a6bc6ca0]
[PiggybackFetcher] Fetch with cache settings: NoCache(<hostname>, base_path=/omd/sites/cmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=90, inventory=90), disabled=True, use_outdated=False, simulation=False)
Piggyback file '/omd/sites/cmk/tmp/check_mk/piggyback/<hostname>/mad-m01-vc01.servidores.ine.es': Successfully processed from source 'mad-m01-vc01.servidores.ine.es'
No piggyback files for '10.10.10.10'. Skip processing.
[cpu_tracking] Stop [7f27a6bc6ca0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<wmi_cpuload:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<fileinfo:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_phydisk>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_if>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_processor>>> / Transition HostSectionParser -> HostSectionParser
<<<df:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<services>>> / Transition HostSectionParser -> HostSectionParser
<<<wmi_webservices:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<ps:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
Transition HostSectionParser -> NOOPParser
Transition NOOPParser -> NOOPParser
<<<systemtime>>> / Transition NOOPParser -> HostSectionParser
Trying to acquire lock on /omd/sites/cmk/var/check_mk/persisted/<hostname>
Got lock on /omd/sites/cmk/var/check_mk/persisted/<hostname>
Releasing lock on /omd/sites/cmk/var/check_mk/persisted/<hostname>
Released lock on /omd/sites/cmk/var/check_mk/persisted/<hostname>
Stored persisted sections: win_cpuinfo, win_os, win_bios, win_system, win_computersystem, win_disks, win_video, win_networkadapter, win_ip_r, win_wmi_software, win_wmi_updates, win_reg_uninstall, win_exefiles
Using persisted section SectionName('win_cpuinfo')
Using persisted section SectionName('win_os')
Using persisted section SectionName('win_bios')
Using persisted section SectionName('win_system')
Using persisted section SectionName('win_computersystem')
Using persisted section SectionName('win_disks')
Using persisted section SectionName('win_video')
Using persisted section SectionName('win_networkadapter')
Using persisted section SectionName('win_ip_r')
Using persisted section SectionName('win_wmi_software')
Using persisted section SectionName('win_wmi_updates')
Using persisted section SectionName('win_reg_uninstall')
Using persisted section SectionName('win_exefiles')
-> Add sections: ['check_mk', 'cmk_agent_ctl_status', 'df', 'fileinfo', 'mem', 'ps', 'services', 'systemtime', 'uptime', 'win_bios', 'win_computersystem', 'win_cpuinfo', 'win_disks', 'win_exefiles', 'win_ip_r', 'win_networkadapter', 'win_os', 'win_reg_uninstall', 'win_system', 'win_video', 'win_wmi_software', 'win_wmi_updates', 'winperf_if', 'winperf_phydisk', 'winperf_processor', 'wmi_cpuload', 'wmi_webservices']
<<<esx_vsphere_vm:cached(1702983662,90)>>> / Transition NOOPParser -> HostSectionParser
No persisted sections
-> Add sections: ['esx_vsphere_vm', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f27a67876d0]
value store: synchronizing
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/counters/<hostname>
Got lock on /omd/sites/cmk/tmp/check_mk/counters/<hostname>
Releasing lock on /omd/sites/cmk/tmp/check_mk/counters/<hostname>
Released lock on /omd/sites/cmk/tmp/check_mk/counters/<hostname>
CPU utilization Total CPU: 4.03%
Check_MK Agent Version: 2.1.0p37, OS: windows, TLS is not activated on monitored host (see details)
Disk IO SUMMARY Read: 33.1 kB/s, Write: 305 kB/s, Latency: 175 milliseconds
ESX Guest Tools VMware Tools are installed, but the version is not current
ESX Snapshots Count: 0
Filesystem C:/ 90.3% used (503.89 of 558.03 GB), trend: +34.63 MB / 24 hours
Interface Conexión de red Gigabit Intel[R] 82574L [1], (Connected), Speed: 1 GBit/s, In: 128 B/s (<0.01%), Out: 9.39 B/s (<0.01%)
Interface Conexión de red Gigabit Intel[R] 82574L 2 [2], (Connected), Speed: 1 GBit/s, In: 127 B/s (<0.01%), Out: 4.69 B/s (<0.01%)
Interface Conexión de red Gigabit Intel[R] 82574L 3 [3], (Connected), Speed: 1 GBit/s, In: 6.14 kB/s (<0.01%), Out: 7.58 kB/s (<0.01%)
Interface Conexión de red Gigabit Intel[R] 82574L 4 [4], (Connected), Speed: 1 GBit/s, In: 241 B/s (<0.01%), Out: 1.47 B/s (<0.01%)
Interface isatap.ine.es [7], (Connected), Speed: 100 kBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface isatap.{55608C67-4548-4661-8072-9F78E8765F6F} [6], (Connected), Speed: 100 kBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface isatap.{A5969D73-C5BA-4810-AC3D-CBC86E27DDAA} [5], (Connected), Speed: 100 kBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface isatap.{DFEA0D50-34E6-4167-BF82-4DA004779A78} [8], (Connected), Speed: 100 kBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Memory RAM: 34.55% - 44.22 GB of 128.00 GB, Commit charge: 67.57% - 97.97 GB of 145.00 GB
Processor Queue 15 min load: 0.40, 15 min load per core: 0.01 (32 logical cores)
Service Summary Autostart services: 74, Stopped services: 10
System Time Offset: -16.7 s
Uptime Up since Dec 02 2023 19:32:30, Uptime: 16 days 16 hours
Web Service Default Web Site Connections: 0.00
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: ok
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: ok
win_disks: skipped (no data)
win_exefiles: ok
win_exefiles: skipped (no data)
win_ip_r: ok
win_ip_r: skipped (no data)
win_networkadapter: ok
win_networkadapter: skipped (no data)
win_reg_uninstall: ok
win_reg_uninstall: skipped (no data)
win_video: ok
win_video: skipped (no data)
win_wmi_software: ok
win_wmi_software: skipped (no data)
win_wmi_updates: ok
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: skipped (no data)
mem: ok
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: skipped (no data)
winperf_if: ok
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: ok
win_bios: skipped (no data)
win_computersystem: ok
win_computersystem: skipped (no data)
win_cpuinfo: ok
win_cpuinfo: skipped (no data)
win_os: ok
win_os: skipped (no data)
win_system: ok
win_system: skipped (no data)
[cpu_tracking] Stop [7f27a67876d0 - Snapshot(process=posix.times_result(user=0.050000000000000044, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.049999999813735485))]
[agent] Success, [piggyback] Successfully processed from source 'mad-m01-vc01.servidores.ine.es', execution time 20.9 sec | execution_time=20.930 user_time=0.050 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=20.880
Please, ¿any help?
BR
