Hello there
since today i got the error (title/screenshot). can you help me troubleshoot? is there a way to “clear” this log?
CMK version: Checkmk Raw Edition 2.1.0p9
OS version: Debian 11
Error message: Local site MYSITE - Livestatus error Malformed raw response output
OMD[monitoring]:/$ omd status
agent-receiver: running
mkeventd: running
rrdcached: running
npcd: running
nagios: running
apache: running
redis: running
crontab: running
Overall state: running
OMD[monitoring]:/$ cmk --paths
Files copied or created during installation
Main components of check_mk : /omd/sites/monitoring/share/check_mk/modules/
Checks : /omd/sites/monitoring/share/check_mk/checks/
Notification scripts : /omd/sites/monitoring/share/check_mk/notifications/
Inventory plugins : /omd/sites/monitoring/share/check_mk/inventory/
Agents for operating systems : /omd/sites/monitoring/share/check_mk/agents/
Documentation files : /omd/sites/monitoring/share/doc/check_mk/
Check_MK's web pages : /omd/sites/monitoring/share/check_mk/web/
Check manpages (for check_mk -M) : /omd/sites/monitoring/share/check_mk/checkman/
Binary plugins (architecture specific) : /omd/sites/monitoring/lib/
Templates for PNP4Nagios : /omd/sites/monitoring/share/check_mk/pnp-templates/
Startscript for Nagios daemon : /omd/sites/monitoring/etc/init.d/core
Path to Nagios executable : /omd/sites/monitoring/bin/nagios
Configuration files edited by you
Main configuration file of Nagios : /omd/sites/monitoring/tmp/nagios/nagios.cfg
Directory where Nagios reads all *.cfg files : /omd/sites/monitoring/etc/nagios/conf.d/
Directory that contains main.mk : /omd/sites/monitoring/etc/check_mk/
Directory containing further *.mk files : /omd/sites/monitoring/etc/check_mk/conf.d/
Directory where Apache reads all config files : /omd/sites/monitoring/etc/apache/
Users/Passwords for HTTP basic authentication : /omd/sites/monitoring/etc/htpasswd
Data created by Nagios/Check_MK at runtime
File into which Nagios configuration is written: /omd/sites/monitoring/etc/nagios/conf.d/check_mk_objects.cfg
Path to Nagios status.dat : /omd/sites/monitoring/tmp/nagios/status.dat
Base working directory for variable data : /omd/sites/monitoring/var/check_mk/
Checks found by inventory : /omd/sites/monitoring/var/check_mk/autochecks/
Precompiled host checks : /omd/sites/monitoring/var/check_mk/precompiled/
Stored snmpwalks (output of --snmpwalk) : /omd/sites/monitoring/var/check_mk/snmpwalks/
Current state of performance counters : /omd/sites/monitoring/tmp/check_mk/counters/
Cached output from agents : /omd/sites/monitoring/tmp/check_mk/cache/
Unacknowledged logfiles of logwatch extension : /omd/sites/monitoring/var/check_mk/logwatch/
Sockets and pipes
Nagios' command pipe : /omd/sites/monitoring/tmp/run/nagios.cmd
Nagios' check results directory : /omd/sites/monitoring/tmp/nagios/checkresults
Socket of Check_MK's livestatus module : /omd/sites/monitoring/tmp/run/live
Locally installed addons
Locally installed checks : /omd/sites/monitoring/local/share/check_mk/checks/
Locally installed notification scripts : /omd/sites/monitoring/local/share/check_mk/notifications/
Locally installed inventory plugins : /omd/sites/monitoring/local/share/check_mk/inventory/
Locally installed check man pages : /omd/sites/monitoring/local/share/check_mk/checkman/
Locally installed agents and plugins : /omd/sites/monitoring/local/share/check_mk/agents/
Locally installed Multisite addons : /omd/sites/monitoring/local/share/check_mk/web/
Locally installed PNP templates : /omd/sites/monitoring/local/share/check_mk/pnp-templates/
Locally installed documentation : /omd/sites/monitoring/local/share/doc/check_mk/
Locally installed localizations : /omd/sites/monitoring/local/share/check_mk/locale/
OMD[monitoring]:/$
thanks a lot
edit: i forgott, it’s happening, after i do a “fake check” on a host, to test notifications…
i did already a reboot, its not helping
