CMK version: 2.0.0p29 (CEE)
OS version: Oracle Linux Server release 7.9
This is my logwatch.cfg file:
"/u01/app/odaorabase/oracle/diag/rdbms/*/*/trace/alert_*.log" overflow=C maxcontextlines=2,3
W ^ORA-
So, I need to monitor several alert_*.log files, considering a warning every line that starts with “ORA-”, having 2 previous contextlines and 3 after contextlines.
I’m doing a test using this script:
I=1
while [ true ]
do
echo "PrevContextline 3: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "PrevContextline 2: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "PrevContextline 1: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "ORA-$I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "ORA-17627: test $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "ORA-99999: test $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "PostContextline 1: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "PostContextline 2: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
echo "PostContextline 3: $I" >> /u01/app/odaorabase0/oracle/diag/rdbms/bt99_sbghodat1/BT99_1/trace/alert_BT99_1.log
I=$(($I+1))
sleep 30
done
So, it’s adding some lines to one of the monitored files. Some of them starting with “ORA-” and some pre and post context lines.
When I go to the GUI to see the contents of the logfile, most of the times the capture is fine and it’s showing the lines with the ORA- and the corresponding context lines, but sometimes, it’s missing lines, for example, test 97 was not detected here:
WARN 2023-09-06 10:04:00
ORA-95
ORA-17627: test 95
ORA-99999: test 95
ORA-96
ORA-17627: test 96
ORA-99999: test 96
WARN 2023-09-06 10:05:00
ORA-98
ORA-17627: test 98
ORA-99999: test 98
And a few minutes later, several test lines (from 105 to 114) were missed as well:
WARN 2023-09-06 10:08:00
ORA-103
ORA-17627: test 103
ORA-99999: test 103
ORA-104
ORA-17627: test 104
ORA-99999: test 104
WARN 2023-09-06 10:13:00
ORA-115
ORA-17627: test 115
ORA-99999: test 115
Of course, I checked and the lines are present in the logfile…
What could be the root cause of this?
Thanks and best regards,
Rafael
