I also noticed this after installing a new server with hardware raid.
When using the latest Broadcom ‘driver’ including storcli64 (7.1912), there is no detection of enclosures, disks or virtual drives, our 2.0.0.p16 check_mk_agent.linux still uses the old syntax.
Is this issue noticed by the team, and being worked on? Monitoring the raid arrays is top-prio I would presume.
Hi @moetiker ,
I know it’s been a while, but I am currently addressing this; starting with the replacement of the ‘megaraid_pdisks’ section. Can you supply an example output of the above command?
Thanks! That is a lot of output considering in the end we only show the overall state, the name, and the predictive failure count in the service summary…
Reading the reference, it seems that show status instead of show all might suffice. Since I can’t (currently) access a fitting system, any help is appreciated. (I’ll keep preparing as much as I can until the customer gets back to me.)
Currently I’m planning to add this to the agent:
section_storcli() {
if inpath storcli; then
_storcli() { storcli "$@"; }
elif inpath storcli64; then
_storcli() { storcli64 "$@"; }
else
return 1
fi
echo '<<<storcli_physical_disks>>>'
_storcli /call/eall/sall show all
echo '<<<storcli_virtual_disks>>>'
_storcli /call/vall show all
echo '<<<storcli_battery_backup>>>'
_storcli /call/bbu show all
# exit successfully, because storcli was in the path.
return 0
For all of these I want to see if show status is enough though.
# /opt/MegaRAID/storcli/storcli64 /call/eall show status
CLI Version = 007.0709.0000.0000 Aug 14, 2018
Operating system = Linux 5.4.0-87-generic
Controller = 0
Status = Failure
Description = None
Detailed Status :
Ctrl EID Status ErrCd ErrMsg
0 252 Failed 255 Enclosure not found
# /opt/MegaRAID/storcli/storcli64 /call/bbu show status
Controller = 0
Status = Failure
Description = None
Detailed Status :
Ctrl Status Property ErrMsg ErrCd
0 Failed - Battery is absent! 34
# /opt/MegaRAID/storcli/storcli64 /call/cv show status
Controller = 0
Status = Failure
Description = None
Detailed Status :
0 Failed - Cachevault is absent! 34
Hi guys! I am making some progress. Physical and virtual disks are almost done, but I’m still looking for a an output of storcli /call/cv show all, with actual cache vaults present .
I’m currently building this in the master branch - depending on the feedback we will consider bringing it to the 2.1.
I’ll keep you posted.
# /opt/MegaRAID/storcli/storcli64 /call/cv show all
Controller = 0
Status = Failure
Description = None
Detailed Status :
How I saw in the GitHub project: Commit, the checks are available for the future version 2.1 and won’t be backported to 2.0. I’m a absolut beginner with checkMK and not able to create a MKP which include this patches. Maybe someone of the community have the time to create a extension pack for 2.0?
