I have successfully installed macOS Agent on a few of our Macs. CheckMk server recieves data from the Macs.
Next I would like to monitor if process xyz is running on the Macs. To accomplish this, I created a Process Discovery Rule which I have applied to the folder containing the Mac’s. This approach works fine for Windows hosts, but doesn’t seem to work for the Mac Agent.
I suspect this feature (checking state for a certain process) is not supported by the Mac Agent, but I am not sure. Can anyone point me in the right direction?
Thanks for the reply. I did use the Github script to install the macOS agent, I forgot to mention. It however seems to have very limited fuctionality compared with the Windows agent.
Also, I can see the macOS agent reporting to Checkmk but no such information as for instance on all running processes.
I found that in the output of the agent all running process with their open files are listed. In the discovery rule for the process I have entered the full path to the executable under ‘Process matching’ → Exact name for process without arguments’.
Now it’s working.
