Macro variable not working for check-mk 2.4
**CMK version:**OMD - Open Monitoring Distribution Version 2.4.0p21.cre
OS version:
Distributor ID: Ubuntu
Description: Ubuntu 24.04.2 LTS
**scenario:
  • I had custom perl script to get bgp (network) data status where i have put one simple rule** **“Classical active and passive Monitoring check” - used to work on check-mk 1.6
    check_bgp.0.4.pl -H $_HOSTHOST_IP$ -v 3 -C xxxxx:xxxxxx:sha:xxxxxx:aes -p $_HOSTPEER_IP$
This same rule is not working on check-mk 2.4
i can see rule is present, but variable macro seems to be not working.
provide me solution on how to put variable or macro in check-mk 2.4
The macro $_HOSTHOST_IP$ is not a standard macro, at least in the Checkmk Micro Core based sites. For CMC sites (pro, ult, cloud) that macro is likely $HOSTADDRESS$
Where do you define the $_HOSTPEER_IP$ macro? I am a very visual person, so if you can provide a redacted screenshot, that would help me understand.
I admit that I don’t have a Raw site currently stood up to check the macros against.
Thank @briand for your prompt response.
My issue got fixed, by referring : Standard Macros in Nagios logics.
Glad to hear you got it!
Hello!
Thank you!
