Mail Notification for filled storage
Please how do i configure checkmk to send out mail notifications each day when file system disks are over limit to all users
Just to clarify: Do you mean the whole record or are there any quotas where every single user should get an email for exceeding it?
Otherwise there are several options:
  • Set the interval for the discs to 1 day
  • Build your own check for the hard drives and run it asynchronously (once a day)
  • Set up notification bulking and send it to alle users:
how do i configure checkmk to tell me a filesystem is critical daily
As I mentioned before.
Checkmk usually sends a message for every event, so every time the hard disk is classified as CRIT, a message is sent.
If you only want the messages once a day, then I think notification bulking is the right way for you.
There is also the item Conditions:
Here you can also set bulking for individual services.
how do i configure this
that should be the default.
if a service is getting critical it generates an event which in default sends a notification as configured unter “notifications”. This is per default an email. But you have to set an email-address to your user and you have to configure your postfix so it can send mails.
