Mailstore Gateway Monitoring
I’m using Check_MK Raw Version 2.1.
I tried to monitor the MailstoreGateway service of a server.
The configuration looks like this:
The service at the server looks like this:
does anyone know what’s wrong with this configuration?
Thank you in advance.
Hi @cmk_User,
i guess your rule does not apply because you entered the Windows-Service name in the lower Name of the service box below your hostname, which applies for the checkmk internal service name. Can you please delete it there and try it again?
Hello tosch,
Thank you for your help.
Unfortunately to delete the check from the location you described, didn’t change anything.
The check does still not appear.
Unfortunately i have no 2.1 system on hand to play around and also be not one of the Windows cracks.
Can you check the agent output if the Windows service is included? You may miss a rule to enable general Windows service monitoring in the first place (like it’s the case with process monitoring).
Name of the service is MailstoreGateway and not Mailstore Gateway.
Ralf
It maybe not the same, but a HTTP-Check should also do in most cases.
