Is there documentation for a manual installation of the Linux CheckMK agent ?
I did look, but I couldn’t find anything that doesn’t use the deb/rpm approach. I’m using Arch Linux so needed another approach. Here’s what I did, seems to work - not sure if I am missing anything?
- On the CheckMK server
tar cvf /tmp/agent.tar -C /opt/omd/versions/2.1.0p17.cre/share/check_mk/agents scripts linux/cmk-agent-ctl check_mk_agent.linux
- On the Linux client
First, copy the agent.tar created in step 1, then
mkdir -p /var/lib/cmk-agent
tar xvf agent.tar -C /var/lib/cmk-agent
mv /var/lib/cmk-agent/check_mk_agent.linux /usr/bin/check_mk_agent
mv /var/lib/cmk-agent/linux/cmk-agent-ctl /usr/bin/cmk-agent-ctl
/var/lib/cmk-agent/scripts/super-server/setup deploy
/usr/bin/cmk-agent-ctl dump | head -n 2
- Fix the socket
I found the above installed the domain socket rather than TCP. I fixed that like this
cp /var/lib/cmk-agent/scripts/super-server/0_systemd/check-mk-agent.socket.fallback /usr/lib/systemd/system/check-mk-agent.socket
systemctl daemon-reload
/var/lib/cmk-agent/scripts/super-server/setup trigger
After that, I could tickle the agent
ss -tulpn | grep 6556
And adding the host on CheckMK worked.
It would be nice if this if this was documented and/or a .tar of the required files could be downloaded from Setup->Agents-Linux. Unless I missed something, apologies if I have ![]()
