Memory leak in liveproxyd?
CMK version: 2.1.0p33.cee
OS version: SLES 15.1
in our environment we observed what we consider a memory leak in checkmk or the liveproxyd:
We have a master and 14 remote sites. All these remote sites are already configured in the master, but the connections to 8 of them are still disabled because the servers will be installed later.
Now we can observe this memory behaviour on the master site:
Whenever we did a omd restart on the master site, the memory usage dropped.
We also checked on the shell:
Before a restart. The lines with the big numbers correspond to the not-yet-enabled remotes sites:
master:~> ps -aux | grep liveproxy
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
master   11283  0.1  0.1  49972 19312 ?        S    Aug09  21:16 python3 /omd/sites/master/bin/liveproxyd
master   11284  0.1  0.2 559280 35860 ?        Sl   Aug09  20:08 python3 /omd/sites/master/bin/liveproxyd
master   11285  0.1  0.2 494784 35736 ?        Sl   Aug09  20:20 python3 /omd/sites/master/bin/liveproxyd
master   11287  0.1  0.2 708596 40412 ?        Sl   Aug09  20:07 python3 /omd/sites/master/bin/liveproxyd
master   11289  0.0  0.2 494316 32604 ?        Sl   Aug09  20:00 python3 /omd/sites/master/bin/liveproxyd
master   11291  0.0  0.2 494348 34688 ?        Sl   Aug09  20:02 python3 /omd/sites/master/bin/liveproxyd
master   11294  0.8  8.0 1672132 1292404 ?     S    Aug09 174:02 python3 /omd/sites/master/bin/liveproxyd
master   11297  0.8  8.0 1671896 1292444 ?     S    Aug09 174:09 python3 /omd/sites/master/bin/liveproxyd
master   11311  0.8  8.0 1672176 1292228 ?     S    Aug09 173:59 python3 /omd/sites/master/bin/liveproxyd
master   11316  0.8  8.0 1671936 1292312 ?     S    Aug09 173:55 python3 /omd/sites/master/bin/liveproxyd
master   11322  0.8  8.0 1680436 1292380 ?     Sl   Aug09 173:55 python3 /omd/sites/master/bin/liveproxyd
master   11326  0.8  8.0 1680440 1292372 ?     Sl   Aug09 173:56 python3 /omd/sites/master/bin/liveproxyd
master   11332  0.8  8.0 1672552 1292692 ?     S    Aug09 174:00 python3 /omd/sites/master/bin/liveproxyd
master   11348  0.8  8.0 1672060 1292272 ?     S    Aug09 173:46 python3 /omd/sites/master/bin/liveproxyd
master   11350  0.0  0.2 492804 33948 ?        Sl   Aug09  19:57 python3 /omd/sites/master/bin/liveproxyd
After omd restart. Nothing special. All processes use approx. the same amount of memory.
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
12723 master    20   0  489796  26300   7416 S 0.000 0.164   0:00.10 liveproxy+
12724 master    20   0  492120  29532   7596 S 0.332 0.184   0:00.27 liveproxy+
12726 master    20   0  491116  27784   7148 S 0.000 0.173   0:00.16 liveproxy+
12728 master    20   0  489856  26024   7312 S 0.000 0.162   0:00.09 liveproxy+
12733 master    20   0  489876  26036   7312 S 0.000 0.162   0:00.09 liveproxy+
12735 master    20   0  407968  26192   7312 S 0.000 0.163   0:00.32 liveproxy+
12739 master    20   0  407988  26752   7312 S 0.000 0.166   0:00.31 liveproxy+
12742 master    20   0  408008  26068   7312 S 0.332 0.162   0:00.31 liveproxy+
12746 master    20   0  408028  26012   7312 S 0.000 0.162   0:00.32 liveproxy+
12751 master    20   0  408048  25296   7312 S 0.332 0.157   0:00.32 liveproxy+
12755 master    20   0  408068  26020   7312 S 0.332 0.162   0:00.32 liveproxy+
12758 master    20   0  408088  26028   7312 S 0.332 0.162   0:00.33 liveproxy+
12771 master    20   0  408108  25444   7312 S 0.332 0.158   0:00.33 liveproxy+
12776 master    20   0  490056  26060   7312 S 0.000 0.162   0:00.10 liveproxy+
Three days later. Again, eight processes keep consuming memory. And time.
12723 master    20   0  491672  29364   7660 S 0.000 0.183   6:28.93 liveproxy+
12724 master    20   0  493240  32292   7596 S 0.000 0.201   6:33.28 liveproxy+
12726 master    20   0  492748  32816   7660 S 0.000 0.204   6:29.56 liveproxy+
12728 master    20   0  491752  31492   7544 S 0.000 0.196   6:27.23 liveproxy+
12733 master    20   0  493320  32556   7660 S 0.000 0.202   6:31.74 liveproxy+
12735 master    20   0  824756 445028   7440 S 0.000 2.767  58:34.69 liveproxy+
12739 master    20   0  824784 445184   7440 S 0.000 2.768  58:36.27 liveproxy+
12742 master    20   0  833008 445124   7440 S 0.000 2.768  58:30.76 liveproxy+
12746 master    20   0  824840 445200   7440 S 0.000 2.768  58:32.30 liveproxy+
12751 master    20   0  824868 445328   7440 S 0.000 2.769  58:43.16 liveproxy+
12755 master    20   0  833088 445268   7440 S 0.000 2.769  58:34.47 liveproxy+
12758 master    20   0  824920 445400   7440 S 0.000 2.770  58:39.29 liveproxy+
12771 master    20   0  824936 445380   7440 S 0.000 2.770  58:36.20 liveproxy+
12776 master    20   0  492780  30940   7544 S 0.000 0.192   6:26.97 liveproxy+
Funny thing is, that the disabled connections – at least to my mind – shoudn’t even result in a liveproxyd process. Let alone gobble up memory.
Has anybody else observed this behaviour?
Hey Dirk,
it seems for me i have the same problem.
One liveproxyd process is totaly running out of order and uses 30% of our memory.
We have 3 active slave-sites connected and the fourth site is disabled.
Do you have a solution meanwhile?
Regards,
Andreas
Hi Andreas,
unfortunatley we don’t have a solution yet. But I am somewhat relieved that I am not the only one who faces this behaviour. (Sorry :grimacing:)
We currently just live with this bug and do an omd restart liveproxyd from time to time. The problem occurs only in our test environment because only there we have disabled sites.
Regards,
Dirk
Hi Dirk,
i deleted the livestatus connection for our disabled site and the process disapperad instand. The memory usage is now fine.
One interesting fact:
The problem only occured on one server. We have another server with a disabled livestatus connection and here it’s working fine.
Seems like there is an interesting :beetle:
Regards,
Andreas
