after working successfully for some time with metrics and graphs I setup a new checkmk raw edition instance and configured some metrics again. But the corresponding graph is not generated.
This is my defined graph:
#!/omd/sites/megabert/bin/python3
graph_info.append({
"title" : _("Stability of Internet Connection"),
"metrics" : [
( "quality", "area")
metric_info["quality"] = {
"title": "successful connections",
"unit": "%",
"color": "#00ff00"
This is the local check sample output for which the graph is being created:
<<<<myhostname.domain.tld>>>>
<<<local>>>
P internetconnection quality=100
Questions
- Anything wrong at first sight?
- How can I debug the problem? ($checkmk_instance_home/var/log/web.log shows nothing of relevance)
Edit-1
I renamed the peformance-data-value “quality” to “connection_quality” in order to avoid a possible collision with another value of the same name. No effect.
Edit-2
I of course cleared the browser after applying the file. No effect.
I also executed cmk -R to restart the instance. No effect.
After I stopped the site completely and started it again, now it works.
Edit-3
I finally read here in the forum, that the needed command for applying the metrics is “omd restart apache”.
