Hi There
We are currently migrating old custom CheckMK checks to CheckMK 2.0.
I have already considered the migration documentation and am aware of the differences with Python3.
The checks have been converted with 2to3, works for most Checks, but one error i could not solve.
Seems like there is still something wrong with the type definition, but o could not find where.
Can anybody help?
Thanks Roger
**Exception**
TypeError ('in <string>' requires string as left operand, not NoneType)
**Traceback**
File "/omd/sites/cmktest/lib/python3/cmk/base/checking.py", line 577, in get_aggregated_result
result = _aggregate_results(check_function(**kwargs))
File "/omd/sites/cmktest/lib/python3/cmk/base/checking.py", line 808, in _aggregate_results
perfdata, results = _consume_and_dispatch_result_types(subresults)
File "/omd/sites/cmktest/lib/python3/cmk/base/checking.py", line 852, in _consume_and_dispatch_result_types
for subr in subresults:
File "/omd/sites/cmktest/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 89, in filtered_generator
for element in generator(*args, **kwargs):
File "/omd/sites/cmktest/lib/python3/cmk/base/api/agent_based/register/check_plugins_legacy.py", line 171, in check_result_generator
subresults = sig_function(**kwargs)
File "/omd/sites/cmktest/lib/python3/cmk/base/api/agent_based/register/check_plugins_legacy.py", line 257, in check_migration_wrapper
return original_function(None, params, section)
File "/omd/sites/cmktest/local/share/check_mk/checks/bi_totemomail_queue", line 38, in check_bi_totemomail_queue
if (item in " ".join(line)) and (item == " ".join(line)[:len(item)]):
def inventory_bi_totemomail_queue(info):
p = re.compile('^[0-9a-zA-Z-]*:$')
for line in info:
if p.match(line[0]):
#found an interesting line, yield it to check_mk
yield line[0][:-1], None
def check_bi_totemomail_queue(item, params, info):
pattern_error = re.compile('^error.*$|^DBUnavailable.*$|^directoryUnavailable.*$')
pattern_mailflow = re.compile('^incoming.*$|^outgoing.*$|^spool.*$|^delivery.*$')
for line in info:
if len(item) == len(line[0])-1:
name = line[0]
count = line[1]
if pattern_error.match(name):
if 'error-PW-Mail-detected' in name or 'error-PW-mail-detected' in name:
warn = 25
crit = 50
else:
warn = 1
crit = 1
elif pattern_mailflow.match(name):
warn = 10
crit = 20
if int(count) >= crit:
return (2, "has " + count + " items")
elif int(count) >= warn:
return (1, "has " + count + " items")
elif int(count) < warn:
return (0, "has " + count + " items")
else:
return (3, "Something went wrong")
# declare the check to Check_MK
check_info["bi_totemomail_queue"] = {
'check_function': check_bi_totemomail_queue,
'inventory_function': inventory_bi_totemomail_queue,
'service_description': 'BI Totemomail queue',
